查看: 2829|回复: 1
如SILVACO下程序中 为什么我的输入特性曲线与正常的BJT不同 求各位大神解决
发表于 2015-12-31 10:49:52 | 显示全部楼层 |阅读模式
如下程序中 为什么我的输入特性曲线与正常的BJT不同   求各位大神解决
go athena
line x  location=0.0   spacing=0.08
line x  location=0.5   spacing=0.05
line x  location=0.7  spacing=0.05
line x  location=1.2  spacing=0.08
line x  location=2.0   spacing=0.18
line y  location=0.0   spacing=0.01
line y  location=0.1   spacing=0.02
line y  location=0.5   spacing=0.05
line y  location=0.8   spacing=0.15
#substrate
init silicon c.phos=2e19
diffus time=60 temp=1000  press=1
#collector
epitaxy thick=0.5 time=10 temp=1000 divis=10 ydy=0.05 dy=0.02 min.dy=0.01 c.phos=3e17
#base
deposit sige thick=0.04 divis=8 ydy=0.01 dy=0.02 c.boron=5e18
#emitter
deposit silicon thick=0.07  divis=10 ydy=0.02 dy=0.02 c.phos=1e19
#etch emitter
etch silicon start x=0   y=-0.61
etch         cont  x=0   y=-0.54
etch         cont  x=1.5 y=-0.54
etch         done  x=1.5 y=-0.61
#etch base
etch sige start x=0 y=-0.54
etch      cont  x=1 y=-0.5
etch      done  x=1 y=-0.54
#etch collector
etch silicon   start x=0 y=-0.5
etch           cont  x=0 y=0
etch           cont  x=1 y=0
#etch oxide
deposit oxide thick=0.8 division=4
etch oxide start x=0.4 y=-1.4
etch       cont  x=0.4 y=0
etch       cont  x=0.6 y=0
etch       done  x=0.6 y=-1.4
etch oxide start x=0   y=-1.4
etch       cont  x=0   y=-0.4
etch       cont  x=0.8 y=-0.4
etch       done  x=0.8 y=-1.4
etch oxide start x=1.15   y=-1.4
etch       cont  x=1.15   y=-0.54
etch       cont  x=1.35   y=-0.54
etch       done  x=1.35   y=-1.4
etch oxide start x=0.8     y=-1.4
etch       cont  x=0.8     y=-0.8
etch       cont  x=1.4     y=-0.8
etch       done  x=1.4     y=-1.4
etch oxide start x=1.4   y=-1.4
etch       cont  x=1.4   y=-1
etch       cont  x=2     y=-1.4
etch       done  x=2     y=-1
etch oxide start x=1.9   y=-1.1
etch       cont  x=1.9   y=-0.6
etch       cont  x=2.0    y=-0.6
etch       done  x=2.0    y=-1.1
#etch aluminum
deposit aluminum  thickness=1.2 division=10
etch aluminum start x=0      y=-2.2
etch          cont  x=0      y=-1.2
etch          cont  x=2.0    y=-1.2
etch          done  x=2.0    y=-2.2
etch aluminum start x=0      y=-1.2
etch          cont  x=0.8    y=-0.5
etch          done  x=0.8    y=-1.2
etch aluminum start x=0      y=-0.5
etch          cont  x=0.3    y=-0.4
etch          done  x=0.3    y=-0.5
etch aluminum start x=0.7      y=-0.5
etch          cont  x=0.7      y=-0.4
etch          done  x=0.8      y=-0.5
etch aluminum start x=0.8      y=-1.2
etch          cont  x=0.8      y=-1
etch          cont  x=1.8      y=-1
etch          done  x=1.8      y=-1.2
etch          cont  x=1.0      y=-0.8
etch          done  x=1.0      y=-1
etch aluminum start x=1        y=-1
etch          cont  x=1        y=-0.9
etch          cont  x=1.4      y=-0.9
electrode name=emitter    x=2.0
electrode name=collector       x=0.5
electrode name=base  x=1.1
electrode name=substrate  backside
structure mirror right
structure outf=hbt1.str
go devedit
base.mesh height=0.1 width=0.125
bound.cond max.slope=28 max.ratio=300 rnd.unit=0.003 line.straightening=1 \
   align.points when=automatic
constr.mesh max.angle=90 max.ratio=200 max.height=1 \
    max.width=1 min.height=0.0001 min.width=0.0001
Mesh Mode=MeshBuild
structure outf=00.str
refine mode=y  x1=1.5 y1=-0.61 x2=2.5 y2=-0.53
refine mode=y  x1=1.0 y1=-0.54 x2=3.0 y2=-0.49
go atlas
solve init
impact selb
output con.band val.band
solve  vcollector=0.0 vstep=0.02 name=collector vfinal=2.0
method  newton trap maxtrap=20
log outfile=ying.log master
solve vbase=0.0 vstep=0.02 name=base vfinal=2.0
tonyplot  ying.log
quit
发表于 2020-8-18 19:50:33 | 显示全部楼层
Thanks for sharing.
GMT+8, 2025-12-15 01:32 , Processed in 0.020569 second(s), 6 queries , Gzip On, Redis On.
