查看: 2497|回复: 1
[求助] xilinx ise12.4创建IP核失败
发表于 2015-12-17 11:20:11 | 显示全部楼层 |阅读模式
ERROR:sim - Failed to generate 'kaifang22'.
Wrote file for project 'kaifang22'.
IP creation failed.
WARNING: the originally identified core 'kaifang22.xco' was not created in E:/hhahahaaaaaa/ipcore_dir. If you changed the name in the customization dialog or the location of the core, you'll need to add that core to your project using Add Source...
这是错误提示,,这是什么意思?怎么解决,,跪求大神解答
发表于 2015-12-18 11:00:09 | 显示全部楼层
你就没把IP核加到你工程里
GMT+8, 2025-12-26 01:37 , Processed in 0.018707 second(s), 6 queries , Gzip On, Redis On.
