查看: 1511|回复: 0
[招聘] 【NVIDIA急招】ASIC Physical Design/后端工程师(英伟达上海)
发表于 2015-12-9 15:35:32 | 显示全部楼层 |阅读模式
一.公司简介
       NVIDIA (英伟达™)(www.nvidia.cn)公司(纳斯达克代码:NVDA)是全球视觉计算技术的行业领袖及GPU(图形处理器)的发明者。作为高性能处理器的GPU可在工作站、个人计算机、游戏机和移动设备上生成令人叹为观止的互动图形效果。公司在全球拥有超过8000名员工,总部在加利福尼亚州圣克拉拉。
工作地址:上海研发中心【上海申江路5709号(秋月路26号)矽岸国际2号楼】
二.投递方式
感兴趣请的请将简历发送至:yvettes@nvidia.com;邮件注明“BBS”
我们会认真对待每份简历,保证每份简历都有是否通过简历筛选的回复。同时欢迎随时电话或邮件咨询职位详情,申请进度等等:021-61043660
三.职位详情
1.
ASIC Physical Design engineer
As asenior member of our ASIC-PD team, you'll be working on streamlining the chipinfrastructure process across product designs, focusing on full chip layoutplanning (partitioning, planning clock distribution and other structure,methodology), partition/full chip timing closure (primetime scripts, othertools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
Chip integration and netlist generation
-Synthesis, Formal verification, netlist quality check
Work in conjunction with Place and Route Engineers to achieve timingclosure for both partition level and full chip level
Develop and enhance entire timing flow from frontend (pre-layout) tobackend (post-layout) at both chip and block level.
Develop custom timing scripts using tcl/primetime for clock skewanalysis, special circuits such as clock dividers, core logic <-> IOmacros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
Develop flow to physically partition and floorplan the entire chip.
Develop scripts for performingECO's.
MINIMUMREQUIREMENTS:
BS or MS in Electrical Engineering or Computer Science
relevant ASIC experience ideally with a focus in the chip integration/synthesis/formal and timing closure
- Excellent scripts skills
- Excellent written and verbal communication skills in English
- Ability to multiplex many issues, set priorities, and work in ateam environment
- Keep up to date with leading edge technologies
BestRegards,
YvetteShen
APACStaffing Team
NVIDIASHANGHAI
Building 2, No. 5709 ShenjiangRoad (No.26 Qiuyue Road)  201210.
Tel+(86 21) 61043660
yvettes@nvidia.com
GMT+8, 2025-12-29 03:41 , Processed in 0.015831 second(s), 5 queries , Gzip On, Redis On.
