ERROR ack:198 - NCD was not produced. All logic was removed from the design.
This is usually due to having no input or output PAD connections in the
design and no nets or symbols marked as 'SAVE'. You can either add PADs or
'SAVE' attributes to the design, or run 'map -u' to disable logic trimming in
the mapper. For more information on trimming issues search the Xilinx
Answers database for "ERROR ack:198" and read the Master Answer Record for
MAP Trimming Issues.
下面程序和ucf
module test_top(
input clk_in,
input rst_in
wire [7:0] cosine;
(* KEEP="TRUE"*)wire [7:0] sine;
wire [15:0] phase_out;
DDS_test your_instance_name (
.clk(clk_in), // input clk
.sclr(rst_in), // input sclr
.cosine(cosine), // output [15 : 0] cosine
.sine(sine), // output [15 : 0] sine
.phase_out(phase_out) // output [15 : 0] phase_out
endmodule
# PlanAhead Generated miscellaneous constraints
NET "sine[0]" KEEP = "TRUE";
NET "sine[1]" KEEP = "TRUE";
NET "sine[2]" KEEP = "TRUE";
NET "sine[3]" KEEP = "TRUE";
NET "sine[4]" KEEP = "TRUE";
NET "sine[5]" KEEP = "TRUE";
NET "sine[6]" KEEP = "TRUE";
NET "sine[7]" KEEP = "TRUE";
# PlanAhead Generated physical constraints
NET "clk_in" LOC = V10;
NET "rst_in" LOC = P4;
# PlanAhead Generated IO constraints
NET "clk_in" IOSTANDARD = LVCMOS33;
NET "rst_in" IOSTANDARD = LVCMOS18; |
