查看: 11179|回复: 13
[求助] VCS启动问题
发表于 2015-11-24 14:09:07 | 显示全部楼层 |阅读模式
求助大家:系统是centOS6.5,gcc-4.4.7,scl-11.5,vcs 2014.03
我刚装了VCS, 根据论坛的资源“破解”了,但是在启动的时候出现下列信息, 求教如何解决,是license不能用了吗?
$vcs -help
Sorry, Linux version 2.6.32-431.el6.x86_64 is not supported
For assistance, please contact technical support
at vcs_support@synopsys.com or call 1-800-VERILOG
$vcs -gui
$ dve -mode64
Fatal License Error.
Inconsistent Encryption code in license file.
Make sure that your SNPSLMD_LICENSE_FILE points to the correct server
Please contact VCS Customer Support at 1-800-VERILOG for more information.
 楼主| 发表于 2015-11-24 14:12:06 | 显示全部楼层
信息补充
$ vcs
VCS MX compilation command help:
   (1) Unified use model for all design topologies :
       vcs [libname.]<Top Module_Or_Entity_Or_Config> [compile opts]
   (2) Two step use model for pure verilog design only :
       vcs <source_files> [compile opts]
   where frequently used [compile opts] are,
      [-debug][-debug_all][-o <log_file_name>][+rad][-cm][-sdf][-P <pli tab>]
   For more information,
       About the use model (1), Please refer chapter [4] in VCS MX User Guide or
       About the use model (2), Please refer chapter [3] in VCS User Guide or
       Type vcs -help
$ /usr/synopsys/11.5/amd64/bin/sssverify /usr/synopsys/license/synopsys.dat
Integrity check report for license file "/usr/synopsys/license/synopsys.dat".
Report generated on 23-Nov-2015 (SCL_11.5)
Checking the integrity of the license file....
Valid SSS feature found.
Licensed to mammoth//ZWT 2006
Siteid: <No Site Id>, Server Hostid: 000c29fb3d57, Issued on: N/A
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
发表于 2019-6-9 23:58:29 | 显示全部楼层
楼主我遇到和你同样大问题,你是怎么解决的啊
发表于 2019-6-9 23:59:11 | 显示全部楼层
楼主我是遇到和你同样的问题,请问你是如何解决的? 多谢
发表于 2019-6-12 23:19:49 | 显示全部楼层
楼主我也遇到这样的问题,请问你是如何解决的?多谢
发表于 2019-6-12 23:21:42 | 显示全部楼层
我的问题和你是一模一样的,我是在Red Hat 6.8上面安装的vcs_mx_vJ-2014.12-SP1
发表于 2019-6-13 10:52:49 | 显示全部楼层
楼主装的应该是64的,可以试试vcs -full64 -help, 另外可能license 破解也有问题
发表于 2020-5-21 08:35:03 | 显示全部楼层
一样的问题,求解
发表于 2020-6-17 18:22:40 | 显示全部楼层
JACKIE11 发表于 2015-11-24 14:12
信息补充
$ vcs
我也遇到这个问题,已经解决了,方法是在添加一个环境变量VCS_TARGET_ARCH,如下所示:
export VCS_TARGET_ARCH=amd64
发表于 2021-1-4 16:28:06 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-29 04:10 , Processed in 0.021037 second(s), 6 queries , Gzip On, Redis On.
