查看: 3350|回复: 1
[求助] ise综合问题
发表于 2013-7-21 13:53:44 | 显示全部楼层 |阅读模式
在rtl代码中,例化了DCM_SP和ODDR2两个ise的库文件,在用ise综合时,没有添加这两个库文件,报错如下
ERROR:NgdBuild:604 - logical block ‘1/ODDR2_inst' with type
   'ODDR2' could not be resolved. A pin name misspelling can cause this, a
   missing edif or ngc file, case mismatch between the block name and the edif
   or ngc file name, or the misspelling of a type name. Symbol 'ODDR2' is not
   supported in target 'virtex6'.
NgdBuild:604 - logical block '1/DCM_SP_inst' with type   'DCM_SP' could not be resolved. A pin name misspelling can cause this, a
   or ngc file name, or the misspelling of a type name. Symbol 'DCM_SP' is not
应如何解决?
发表于 2013-7-24 07:27:26 | 显示全部楼层
generate IPs with Coregen and butr *.ngc files into the design directory.
GMT+8, 2025-12-17 07:29 , Processed in 0.018744 second(s), 8 queries , Gzip On, Redis On.
