查看: 3255|回复: 5
DC启动遇到的问题
发表于 2015-11-4 13:16:14 | 显示全部楼层 |阅读模式
[student@Student Workspace]$ dc_shell-t
Fatal: Design Compiler is not enabled. (DCSH-1)
[student@Student Workspace]$ dv
Unable to obtain feature 'Design-Vision ' because:
Error: Can't communicate with the license server. (SEC-12)
Please contact  at student@(none), who is
your local Synopsys license administrator for Synopsys site 000.
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
经过百度发现有人说出错的地方是在:
这是license没有正确的启动。这是有可能是因为license制作过程有问题。  在制作时需要注意license工具里面的两个文件:一为EFA LicGen 0.4b文件加里面的licgen.dll,该文件不能是老版本的。另一文件为EFA LicGen 0.4b/packs/synopsys.src,license启动不成功很有可能是因为该文件导致生成的license不能启动。
我检查了一下license file是没问题的:
Integrity check report for license file "/usr/synopsys/license/synopsys.dat".
Report generated on 04-Nov-2015 (SCL_11.5)
Checking the integrity of the license file....
Valid SSS feature found.
Licensed to mammoth//ZWT 2006
Siteid: <No Site Id>, Server Hostid: 000c29ce7c24, Issued on: N/A
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
发表于 2016-1-29 12:53:21 | 显示全部楼层
楼主,有木有解决啊,我也遇到同样的问题!!!
发表于 2016-12-26 06:56:57 | 显示全部楼层
我也遇到一样的问题,License check OK, 但是还是启动不了
发表于 2016-12-26 07:03:13 | 显示全部楼层
遇到了同样的问题
发表于 2017-7-22 17:18:38 | 显示全部楼层
楼主没有 解决你发出来干啥,你是求助吗
发表于 2019-11-7 17:15:14 | 显示全部楼层
楼主的帖子没营养啊,咋解决的??求指点啊
GMT+8, 2025-12-29 03:26 , Processed in 0.019597 second(s), 6 queries , Gzip On, Redis On.
