查看: 2693|回复: 1
[求助] Rabaey 的数字IC第二版 的一道习题
发表于 2015-10-28 15:02:19 | 显示全部楼层 |阅读模式
悬赏120资产未解决
Consider a CMOS inverter followed by a wire of length L. Assume that in the
reference design, inverter and wire contribute equally to the total propagation delay tpref. You
may assume that the transistors are velocity-saturated. The wire is scaled in line with the ideal
wire scaling model. Assume initially that the wire is a local wire
a. Determine the new (total) propagation delay as a a function of t
pref, assuming that technology and supply voltage scale with a factor 2. Consider only first-order effects.
b. Perform the same analysis, assuming now that the wire scales a global wire, and the wire
length scales inversely proportional to the technology
啥叫reference design?
什么是ideal wire scaling model?, local wire 和 global wire 又指的是什么?
大神在何方......
 楼主| 发表于 2015-11-6 20:12:26 | 显示全部楼层
好吧我会了,没人理我~~
GMT+8, 2025-12-21 10:12 , Processed in 0.013733 second(s), 6 queries , Gzip On, Redis On.
