查看: 15171|回复: 28
IP参考网站
发表于 2004-1-17 17:56:18 | 显示全部楼层 |阅读模式
自己觉得需要就去下载吧!那个网站会经常更新项目的。
http://www.opencores.org/projects/
Arithmetic core
HCSA adder and Generic ALU based on HCSA
Unsigned serial divider
CORDIC core
CF FFT
radix 4 complex fft
Hardware Division Units
PYRAMID Integer Multiplier unit
CF Floating Point Multiplier
CF Cordic
HIERARCHICAL Integer Multiplier unit
Communication controller
Ethernet MAC 10/100 Mbps
CAN Protocol Controller
Single Slot PCM Interface
Simple Asynchronous Serial Controller
SPI core
Automatic BAUD rate generator
EPP v1.9
I2C controller core
HDB3/B3ZS Encoder+Decoder
SPI controller core
Serial Uart
IrDA
USB 2.0 Function Core
USB 1.1 Function IP Core
HDLC controller
UART 16550 core
General-Purpose I/O (GPIO) Core
USB 1.1 PHY
TDM controller
Reverse CDMA Access Channel Controller
Coprocessor
Floating Point Unit
CF Reconfigurable Computing Array
Crypto core
DES/Triple DES IP Cores
AES (Rijndael) IP Core
DSP core
Low Power FIR Filter
CF FIR Filter
Biquad IIR Filter Core
ECC core
CF LDPC Decoder
Memory core
Single Port ASRAM
Parameterisable DRAM model
Memory sizer
Memory cores
Generic FIFOs
DDR SDRAM Controller Core
CF Interleaver
Microprocessor
Core Unit - 16 bit Processors
T80 cpu
RISC5x
AVR Core
Yellow Star
16 Bit Microcontroller
OpenRISC 1000
tiny8
pAVR
CF State Space Processor
Mini-Risc core
Plasma - most MIPS I(TM) opcodes
Data Flow Processor
AX8 mcu
Cpu Generator
RISC Microcontroller
risc16f84
ASPIDA
Aquarius
PPX16 mcu
nnARM core
Other
PS2 interface
First File Reader FAT16
SoC/OpenRISC Development Interface
PWM/Timer/Counter (PTC) Core
Keypad Scanner
DragonBall/68K Wishbone interface
JTAG Test Access Port (TAP)
Simple Programmable Interrupt Controller
Simple General Purpose IO
WB Interface for TI 5x DSP (WB2HPI)
Prototype board
Micro FPGA Board
OCRP-1 board
SoC
WISHBONE DMA/Bridge IP Core
WISHBONE Conmax IP Core
WISHBONE Conbus IP Core
System controller
PCI bridge
RS232 system controller
OCIDEC (OpenCores IDE Controller)
Memory Controller IP Core
AC 97 Controller IP Core
Video controller
Video compression systems
VGA/LCD Controller
发表于 2004-1-29 13:57:08 | 显示全部楼层
IP参考网站
请问哪里有8051的verilog源代码?
发表于 2004-4-29 10:13:15 | 显示全部楼层
IP参考网站
请问哪里有FIR滤波器的源代码?
发表于 2004-5-15 09:20:38 | 显示全部楼层
IP参考网站
这些OPENCORES上都有,不过有些IP放不了多久就被删掉了,需要地话可与我联系:
sunjh@bjut.edu.cn
发表于 2004-6-16 21:48:18 | 显示全部楼层
IP参考网站
请问哪里有pci slave vhdl 源代码?
发表于 2005-2-23 18:45:02 | 显示全部楼层
IP参考网站
好样的
发表于 2005-3-29 23:58:47 | 显示全部楼层
IP参考网站
好,我经常去
发表于 2005-5-25 14:55:53 | 显示全部楼层
IP参考网站
好东西!
发表于 2005-6-5 15:34:43 | 显示全部楼层
IP参考网站
赶紧瞧瞧去
发表于 2005-9-14 15:48:56 | 显示全部楼层
IP参考网站
太太感谢了:)
GMT+8, 2025-12-29 09:01 , Processed in 0.028155 second(s), 8 queries , Gzip On, Redis On.
