查看: 3026|回复: 8
Error starting HITKIT 4.0 in cadence 615
发表于 2015-10-10 22:19:49 | 显示全部楼层 |阅读模式
Hi,
I have recently installed newer version of virtuoso (6.1.5-32bit). My PDK provider is AustriaMicrosystems (AMS). HitKit(version 4) has been installed with all updates available.
When I start virtuoso (by executing ams_cds command) there are some errors reported in CIW window:
Kind Regards and many thanks in advance for help and suggestions.
PB.
发表于 2015-10-22 21:22:58 | 显示全部楼层
from the snap picture, it looks like some environment variables should be assigned before you start installation ... , any readme first file in the PDK ?
发表于 2015-10-22 21:26:20 | 显示全部楼层
please check the Hitkit compatibility with virtuoso
 楼主| 发表于 2015-10-26 14:36:58 | 显示全部楼层
回复 2# whyarthur
No..I did not get any read me file with this PDK. I have downloaded the Hitkit 4.0 from eetop only.
 楼主| 发表于 2015-10-26 14:38:49 | 显示全部楼层
回复 3# designstart
I am using cadence virtuoso 6.1.5. Which hitkit will be compatible with his version.
Or
which virtuoso version is compatible with hitkit 4.0?
Thank you in advance
发表于 2015-10-26 19:48:25 | 显示全部楼层
回复 5# priyank
   plz read your hitkit4.0 release note
 楼主| 发表于 2015-10-27 16:25:53 | 显示全部楼层
Reply 6 # DesignStart
Thank you for the response.. I have attached the readme file that came along with the hitkit download.
Actually I am using virtualbox 5.0 in windows 7 and have installed ubuntu 14.10 in virtualbox. the readme file says it has been tested in RH7. So should I install RH7 to make it work?
发表于 2015-10-27 21:37:30 | 显示全部楼层
回复 7# priyank
   yes  you'd better use RH7
 楼主| 发表于 2015-10-27 23:10:28 | 显示全部楼层
Reply 8 # DesignStart
Sorry,   I did not read the readme file properly.  here are some snaps of readme file.
GMT+8, 2025-12-20 17:49 , Processed in 0.023738 second(s), 6 queries , Gzip On, Redis On.
