查看: 6744|回复: 23
[资料] 共享:声表面波滤波器
发表于 2015-10-9 21:23:51 | 显示全部楼层 |阅读模式
SurfaceAcousticWaveFilters.PDF (3.47 MB , 下载次数: 227 )
发表于 2015-10-10 14:34:49 | 显示全部楼层
是设计还是规格书?
 楼主| 发表于 2015-10-10 15:15:17 | 显示全部楼层
Surface Acoustic Wave Filters, Second Edition: With Applications to Electronic Communications and Signal Processing
David Morgan(作者)
出版社: Academic Press
丛书名: Studies in Electrical and Electronic Engineering
精装: 448页
语种: 英语
作者简介:
David P. Morgan received a Ph.D. degree in Electrical Engineering from London University, for work on radar pulse compression using Surface Acoustic Waves. Since then he has been involved in research and development in a wide variety of topics, mostly in SAW, working at Nippon Electric Company (Kawasaki) 1970-71, University of Edinburgh 1971-77 and Plessey Research Caswell (Northampton, UK) 1977-86, where he was Group Leader for Surface Acoustic Waves. He is now a Consultant in this area. Dr. Morgan is author of the well-known text ‘Surface Wave Devices for Signal Processing’, and has also published over 100 technical papers. His knowledge of the SAW area has led to his being invited to lecture on the subject in the U.S., Russia, Finland, Japan, China and Korea. He is a Life Senior Member of the IEEE.
目录:
Preface; Foreword; Basic Survey; Acoustic waves in elastic solids; Electrical excitation at a plane surface; Propagation effects and materials; Non-reflective transducers; Bandpass filtering using non-reflective transducers; Correlators for pulse compression radar and communications; Reflective gratings and transducers; Unidirectional transducers and their application to bandpass filtering; Waveguides and transversely-coupled resonator (TCR) filters; Resonators and resonator filters; Appendix A. Fourier transforms and linear filters; Appendix B. Reciprocity; Appendix C. Elemental charge density for regular electrodes; Appendix D. P-matrix relations; Appendix E. Electrical loading in an array of regular electrodes
发表于 2015-10-10 21:37:19 | 显示全部楼层
好资料,下载了,多谢!!
发表于 2015-10-11 22:50:39 | 显示全部楼层
非常感谢提供!
发表于 2015-10-12 11:55:13 | 显示全部楼层
多谢楼主分享!
发表于 2015-10-19 22:48:45 | 显示全部楼层
回复 1# RFplayer
   thanks
发表于 2015-10-22 03:17:16 | 显示全部楼层
good to get it
 楼主| 发表于 2016-2-21 11:55:05 | 显示全部楼层
ding起!
 楼主| 发表于 2016-3-2 12:38:56 | 显示全部楼层
顶上去
GMT+8, 2025-12-29 02:20 , Processed in 0.029323 second(s), 6 queries , Gzip On, Redis On.
