查看: 2993|回复: 1
[求助] ISE14.7生成IP核遇到的问题
发表于 2015-10-6 20:30:55 | 显示全部楼层 |阅读模式
在生成Adder IP核时遇到了这样的问题:
ERROR:sim - Failed to run command ' -cg_exc_inp "F:/Xilinx/Verilog
   project/Verilog Lesson/verilog
   language/test/ipcore_dir/tmp/_cg/_dbg/xil_975.in" -cg_exc_out
   "F:/Xilinx/Verilog project/Verilog Lesson/verilog
   language/test/ipcore_dir/tmp/_cg/_dbg/xil_975.out" -namelock'. Executable
   file not found.
ERROR:sim - Failed executing Tcl generator.
ERROR:sim - Failed to generate 'adder'.  Failed executing Tcl generator.
发表于 2015-10-7 10:28:22 | 显示全部楼层
估计是你的ise没有安装好
GMT+8, 2025-12-17 20:09 , Processed in 0.013999 second(s), 6 queries , Gzip On, Redis On.
