查看: 3711|回复: 2
[求助] DCT流程具体如何操作[已解决]
发表于 2015-9-5 14:58:31 | 显示全部楼层 |阅读模式
5.  Ensure that you have all the necessary design-specific input files to be used
    in the flow.  These files are picked up automatically from the search path
    defined in common_setup.tcl
    The minimum recommended files are
    o  ${DCRM_CONSTRAINTS_INPUT_FILE} (Logical design constraints)
    o  ${DCRM_DCT_DEF_INPUT_FILE} or ${DCRM_DCT_FLOORPLAN_INPUT_FILE}
       (floorplan to use for topographical mode synthesis)
    o  ${DCRM_DFT_SIGNAL_SETUP_INPUT_FILE} (DFT signal definitions)
    For a complete list of expected input files, see the list at the end
    of this README file.
从图上来看,我是要先使用dc进行综合,这里dc会粗略地布一下局,然后综合出结果。然后我用dc综合出来的结果进行icc综合。icc综合后会有一份def文件,我再把这份def文件当作dc的输入,再进行一次icc综合?
 楼主| 发表于 2015-9-7 03:16:47 | 显示全部楼层
DC 1st synethesis->desing floorplan->DC 2nd synthesis->ICC layout,看一看student guide
发表于 2024-6-3 10:32:46 | 显示全部楼层
请问大佬,可否分享下dct student guide,非常感谢
GMT+8, 2025-12-21 01:46 , Processed in 0.015977 second(s), 6 queries , Gzip On, Redis On.
