查看: 2858|回复: 1
[原创] ic616刚装好就出现fatal问题打不开,po上Log求解决
发表于 2015-9-4 23:09:14 | 显示全部楼层 |阅读模式
startdate:Fri Sep 4 08:05:03 2015
crashdate:Fri Sep 4 08:05:09 2015
appname:virtuoso
version(#)$CDS: virtuoso version 6.1.6 08/12/2015 22:44 (sjfnl116) $
subversion:IC6.1.6.500.13
mem:65511424 (total 1036849152)
memavail:2603728k (total 3044156k)
signal:SegFault(11)
user:shanshan
host:shanshan (x86_64)
osinux
osversion: 2.6.32-358.el6.x86_64 #1 SMP Fri Feb 22 00:31:26 UTC 2013 x86_64
xserver:CentOS
xversion:11.0 (vendor release 11500000)
display::0.0
qtversion:4.7.2
cdslog:/tmp/crashReport_090415_0805_IC6.1.6.500.13_shanshan_shanshan.log.CDS.log
warning:45:*WARNING* Process was terminated with SIGSEGV signal
signal_by:system
stack::__kernel_rt_sigreturn+0()
stack:virtuoso:cds_pl_check+2934()
stack:virtuoso:inflate_fast+2783()
stack:virtuoso:cdsPInit+1216()
stack:virtuoso:TE_lmCheckOut+272()
stack:virtuoso:icLicLocalCheckOut(char const*, double, int, int, int, int (*)(char const*, double, int, int, int, int))+322()
stack:virtuoso:icLicCheckOut+92()
stack:virtuoso:_dbGetLicense+116()
stack:virtuoso:dbiInit+23()
stack:libil_sh.so:iliInitClients+961()
stack:virtuoso:main+831()
userenv:A__z="*SHLVL
userenv:CDNS_QTDIR=/home/shanshan/cadence/ic616/tools/Qt/32bit
userenv:CDS=/home/shanshan/cadence/ic616
userenv:CDS_ARCH=lnx86
userenv:CDS_LANG=en_US.utf8
userenv:CDS_LIC_FILE=5280@shanshan
userenv:CDS_MPS_SESSION=virtuoso2801
userenv:CDS_Netlisting_Mode=Analog
userenv:CDS_SET_LOCALE=C
userenv:COLORTERM=gnome-terminal
userenv:CVS_RSH=ssh
userenvBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-zM55YDfJXZ,guid=0116558a2577402ce401a2740000003b
userenvESKTOP_SESSION=gnome
userenvISPLAY=:0.0
userenv:GDMSESSION=gnome
userenv:GDM_KEYBOARD_LAYOUT=us
userenv:GDM_LANG=en_US.utf8
userenv:GNOME_DESKTOP_SESSION_ID=this-is-deprecated
userenv:GNOME_KEYRING_PID=2543
userenv:GNOME_KEYRING_SOCKET=/tmp/keyring-5wFWIf/socket
userenv:GTK_RC_FILES=/etc/gtk/gtkrc:/home/shanshan/.gtkrc-1.2-gnome2
userenv:G_BROKEN_FILENAMES=1
userenv:HISTCONTROL=ignoredups
userenv:HISTSIZE=1000
userenv:HOME=/home/shanshan
userenv:HOSTNAME=shanshan
userenvANG=C
userenvC_ALL=C
userenv:LD_LIBRARY_PATH=/home/shanshan/cadence/ic616/tools/lib:/home/shanshan/cadence/ic616/tools/Qt/32bit/lib:/home/shanshan/cadence/ic616/oa_v22.43.053/lib/linux_rhel50_gcc44x_32/opt:/home/shanshan/cadence/ic616/tools/dfII/lib:/home/shanshan/cadence/ic616/tools/sev/lib:/home/shanshan/cadence/ic616/tools/inca/lib
userenv:LESSOPEN=|/usr/bin/lesspipe.sh %s
userenv:LM_LICENSE_FILE=/home/shanshan/cadence/ic616/share/license/license.dat
userenv:LOGNAME=shanshan
userenv:MAIL=/var/spool/mail/shanshan
userenv:MMSIM_ROOT=/home/shanshan/cadence/mmsim13
userenv:MOZILLA_HOME=/usr/bin/netscape
userenv:OA_BIT=32
userenv:OA_HOME=/home/shanshan/cadence/ic616/oa_v22.43.053
userenv:ORBIT_SOCKETDIR=/tmp/orbit-shanshan
userenvATH=/home/shanshan/cadence/ic616/bin:/home/shanshan/cadence/ic616/tools/bin:/home/shanshan/cadence/ic616/oa_v22.43.053/bin:/home/shanshan/cadence/mmsim13/tools/bin:/home/shanshan/cadence/mmsim13/tools/spectre/bin:/home/shanshan/cadence/ic616/tools/dfII/bin:/home/shanshan/cadence/mmsim13/tools/bin:/home/shanshan/cadence/mmsim13/tools/spectre/bin:/home/shanshan/cadence/ic616/tools/dfII/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/shanshan/bin
userenvWD=/home/shanshan/Desktop
userenvTDIR=/usr/lib64/qt-3.3
userenvTINC=/usr/lib64/qt-3.3/include
userenvTLIB=/usr/lib64/qt-3.3/lib
userenv:SHELL=/bin/bash
userenv:SHLVL=6
userenv:SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
userenv:SSH_AUTH_SOCK=/tmp/keyring-5wFWIf/socket.ssh
userenv:TERM=xterm
userenv:USER=shanshan
userenv:USERNAME=shanshan
userenv:W3264_ENV=/home/shanshan/.kshrc
userenv:WINDOWID=48234690
userenv:WINDOWPATH=1
userenv:XAUTHORITY=/var/run/gdm/auth-for-shanshan-slHg5n/database
userenv:XDG_SESSION_COOKIE=bbfa23a73b9199b7884ee3d80000001f-1441379044.288599-973567686
userenv:XTAPPPEEKEVENT_SKIPTIMER=1
userenv:_=*2801*/home/shanshan/cadence/ic616/tools/bin/32bit/cdsCrashReport
userenv:__DFII_INTEG_NC_PATH__=/home/shanshan/cadence/ic616/tools/inca/bin
userenv:_dfII_bin_bit=
userenv:df2BaseVhdlin=/home/shanshan/cadence/ic616
xdpyinfo:name of display:    :0.0
xdpyinfo:version number:    11.0
xdpyinfo:vendor string:    CentOS
xdpyinfo:vendor release number:    11500000
xdpyinfo:maximum request size:  16777212 bytes
xdpyinfo:motion buffer size:  256
xdpyinfo:bitmap unit, bit order, padding:    32, LSBFirst, 32
xdpyinfo:image byte order:    LSBFirst
xdpyinfo:number of supported pixmap formats:    7
xdpyinfo:supported pixmap formats:
xdpyinfo:    depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo:    depth 4, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo:    depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range:    minimum 8, maximum 255
xdpyinfo:focus:  window 0x3000053, revert to PointerRoot
xdpyinfo:number of extensions:    30
xdpyinfo:    BIG-REQUESTS
xdpyinfo:    Composite
xdpyinfo:    DAMAGE
xdpyinfo:    DOUBLE-BUFFER
xdpyinfo:    DPMS
xdpyinfo:    DRI2
xdpyinfo:    GLX
xdpyinfo:    Generic Event Extension
xdpyinfo:    MIT-SCREEN-SAVER
xdpyinfo:    MIT-SHM
xdpyinfo:    Present
xdpyinfo:    RANDR
xdpyinfo:    RECORD
xdpyinfo:    RENDER
xdpyinfo:    SECURITY
xdpyinfo:    SGI-GLX
xdpyinfo:    SHAPE
xdpyinfo:    SYNC
xdpyinfo:    VMWARE_CTRL
xdpyinfo:    X-Resource
xdpyinfo:    XC-MISC
xdpyinfo:    XFIXES
xdpyinfo:    XFree86-DGA
xdpyinfo:    XFree86-VidModeExtension
xdpyinfo:    XINERAMA
xdpyinfo:    XINERAMA
xdpyinfo:    XInputExtension
xdpyinfo:    XKEYBOARD
xdpyinfo:    XTEST
xdpyinfo:    XVideo
xdpyinfo:default screen number:    0
xdpyinfo:number of screens:    1
xdpyinfo:screen #0:
xdpyinfo:  dimensions:    1280x768 pixels (339x203 millimeters)
xdpyinfo:  resolution:    96x96 dots per inch
xdpyinfo:  depths (7):    24, 1, 4, 8, 15, 16, 32
xdpyinfo:  root window id:    0xe2
xdpyinfo:  depth of root window:    24 planes
xdpyinfo:  number of colormaps:    minimum 1, maximum 1
xdpyinfo:  default colormap:    0x20
xdpyinfo:  default number of colormap cells:    256
xdpyinfo:  preallocated pixels:    black 0, white 16777215
xdpyinfo:  options:    backing-store WHEN MAPPED, save-unders NO
xdpyinfo:  largest cursor:    64x64
xdpyinfo:  current input event mask:    0xfac033
xdpyinfo:    KeyPressMask             KeyReleaseMask           EnterWindowMask
xdpyinfo:    LeaveWindowMask          KeymapStateMask          ExposureMask
xdpyinfo:    StructureNotifyMask      SubstructureNotifyMask   SubstructureRedirectMask
xdpyinfo:    FocusChangeMask          PropertyChangeMask       ColormapChangeMask
xdpyinfo:  number of visuals:    64
xdpyinfo:  default visual id:  0x21
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x21
xdpyinfo:    class:    TrueColor
xdpyinfo:    depth:    24 planes
xdpyinfo:    available colormap entries:    256 per subfield
xdpyinfo:    red, green, blue masks:    0xff0000, 0xff00, 0xff
xdpyinfo:    significant bits in color specification:    8 bits
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa3
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa4
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa5
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa6
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa7
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa8
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xa9
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xaa
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xab
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xac
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xad
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xae
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xaf
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb1
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb2
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb3
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb4
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb5
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb6
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb7
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb8
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xb9
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xba
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xbb
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xbc
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xbd
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xbe
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xbf
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc1
xdpyinfo:    class:    DirectColor
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc2
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc3
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc4
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc5
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc6
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc7
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc8
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xc9
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xca
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xcb
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xcc
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xcd
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xce
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xcf
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd1
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd2
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd3
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd4
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd5
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd6
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd7
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd8
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xd9
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xda
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xdb
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xdc
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xdd
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xde
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xdf
xdpyinfo:  visual:
xdpyinfo:    visual id:    0xe0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x42
xdpyinfo:    depth:    32 planes
sysconf:=====================================================================
sysconf:[Copyright 2002-2011] Cadence Design Systems, Inc. All rights reserved.
sysconf:This  program and online  documentation  may not be copied, modified,
sysconf:re-published, uploaded,  executed, or  distributed in any way, in any
sysconf:medium, whether in whole or in part, without prior written permission
sysconf:from Cadence Design Systems, Inc.
sysconf:============== checkSysConf:  Version 3.19 ====================
sysconf:Configuration checks failed on this workstation (shanshan), status is: FAIL
sysconf:The specified software release 'IC6.1.6' is not supported
发表于 2016-1-11 20:26:24 | 显示全部楼层
the same problem occurred tome,had you solved?
GMT+8, 2025-12-21 08:32 , Processed in 0.042573 second(s), 6 queries , Gzip On, Redis On.
