查看: 12950|回复: 7
[求助] 标准单元库 LVS验证 出现property error
发表于 2015-8-26 09:51:39 | 显示全部楼层 |阅读模式
大家好,我最近在做版图设计时(chart 0.18 um工艺)用了arm的标准单元库里的一些cell,但其中的NOR和NAND在做LVS时总会有property error,而AND、INV、BUF和DFFR都正常(只用到了这些)。单独做NOR的LVS也有property error,report 如下:
NOR2X2版图
NOR2X2版图
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Property errors.
LAYOUT CELL NAME:         NOR2X2
SOURCE CELL NAME:         NOR2X2
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              5         5
Nets:               7         7
Instances:          2         2         MN (4 pins)
                     4         4         MP (4 pins)
                     1         0    *    D (2 pins)
Total Inst:         7         6
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              5         5
Nets:               5         5
Instances:          1         1         _nor2v (5 pins)
Total Inst:         1         1
       * = Number of objects in layout different from number in source.
                                      PROPERTY ERRORS
DISC#  LAYOUT                                                    SOURCE                      ERROR
  1    M4(1.920,2.800)  MP(PMOS_1P8)                             Mm5  MP(PMOS_1P8)
       m: -3.40282e+38                                           m: -3.40282e+38
  2    M5(2.480,2.800)  MP(PMOS_1P8)                             Mm3  MP(PMOS_1P8)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               5          5            0            0
   Nets:                5          5            0            0
   Instances:           1          1            0            0    _nor2v
   Total Inst:          1          1            0            0
o Statistics:
   1 layout instance was filtered and its pins removed from adjoining nets.
   4 layout mos transistors were reduced to 2.  1 connecting net was deleted.
     2 mos transistors and 1 connecting net were deleted by split-gate reduction.
   4 source mos transistors were reduced to 2.  1 connecting net was deleted.
o Initial Correspondence Points:
   Ports:        VDD VSS Y A B
其中的红色加粗部分就是出现的错误信息,不知道这是什么错误,m: -3.40282e+38又是什么参数,还望大神指点,多谢!
发表于 2015-8-26 11:04:09 | 显示全部楼层
看你的trace property 容差是多少, 1~5% 都是可以忍受的,
或者问下vendor也行
 楼主| 发表于 2015-8-26 15:21:49 | 显示全部楼层
回复 2# icfbicfb
你好,我试着将tolerance改成了5%,但还是有那个错误。请问通常报property error,除了原理图和版图中管子尺寸不匹配,还有可能是什么原因啊?
因为看这错误应该不是尺寸不匹配。
多谢
发表于 2015-8-27 06:11:08 | 显示全部楼层
结果看不懂, 太老的库了,问vendor吧,
发表于 2016-7-17 20:27:18 | 显示全部楼层
兄弟问题解决了么?咋解决的?
我也遇到类似的了
发表于 2021-12-19 19:03:06 | 显示全部楼层
啊啊啊啊啊,所以这个问题到底是因为啥,我明明对称的两个电阻,上面的就匹配,下面的不匹配,显示阻值不一样,玄幻
发表于 2021-12-21 17:19:04 | 显示全部楼层
努力的咸鱼 发表于 2021-12-19 19:03
啊啊啊啊啊,所以这个问题到底是因为啥,我明明对称的两个电阻,上面的就匹配,下面的不匹配,显示阻值不一 ...
你将LVS Rule中的这个option改一下试试:
LVS RECOGNIZE_GATES    ALL  改为
LVS RECOGENIZE_GATE    NONE
发表于 2024-6-5 01:10:28 | 显示全部楼层
请问楼主这个问题解决了吗,2024年了还在被这个问题折磨
GMT+8, 2025-12-14 22:37 , Processed in 0.021624 second(s), 6 queries , Gzip On, Redis On.
