查看: 2532|回复: 1
[招聘] 上海顶尖IC创业团队诚招模拟及数字工程师
发表于 2015-8-20 21:29:19 | 显示全部楼层 |阅读模式
We're an IC design startup located in Shanghai. We're a team of IC veterans that have built or helped build successful startups in US and China, and is backed by the most prominent VCs in semiconductor industry. We're looking for capable and passionate candidates to join us and build a top design team together!
Analog IC Design Engineer:
As an Analog IC Design Engineer you will perform analog and mixed signal design, characterization and evaluation of analog circuits such as high-speed amplifiers, wireline transmitters, PLL, or other baseband circuits like LDO, temperature sensor etc.
Responsibilities:
- Design and R&D of wideband analog circuits.
- Use EDA tool to run simulation and function verification.
- Guide layout engineer to optimize layout
- Chip debug and testing individually
- Design and optimize chip layout
Experience/Skills:
- MSEE in analog IC design;
- Experience in Cadence EDA tools;
- Team player with good communication skills
- Speciality in EE and Microelectronic
- Minimum 5 years experience in mixed signal circuit design for Master’s degree
- Experience with Serdes transmitter/receiver, TIA, CDR, LNA etc. is highly preferred.
Digital IC Design Engineer:
Job description:
This position is for a digital design engineer supporting mixed signal IC developments.
- RTL coding for logic models
- Simulation/verification of functionalities at both module level and top level
- Module level synthesis / timing analysis / P&R
- Design/verification design review/ report
- Silicon debug of related model functionalities
Qualification:
- BSEE with minimum 3-year or MSEE with minimum 1-year experience of digital experience
- Experience on serial interface design (eg. SPI, I2C)
- Relevant experience in high-speed digital design (Semi-flow: customer layout + ASIC flow) is must
- Solid knowledge of digital design building blocks
- Strong skills of Verilog RTL coding, verification and debug
- Hands on experience in EDA tools such as Cadence NC-Sim, Synopsys DC, PT, etc.
Compensation:
Competitive salary plus generous stock options.
Please send your resume to: jobs@photonic-tech.com
发表于 2015-8-21 15:12:12 | 显示全部楼层
回复 1# ptech
    It's an unavailable email address
GMT+8, 2025-12-28 12:03 , Processed in 0.029148 second(s), 7 queries , Gzip On, Redis On.
