查看: 2873|回复: 5
[讨论] 有坛友熟悉奥地利微电子AMS H18工艺的吗?
发表于 2015-8-20 11:04:21 | 显示全部楼层 |阅读模式
探讨探讨
发表于 2015-8-20 12:19:15 | 显示全部楼层
没做过,不过0.18 能有多滑头呢,都差不多的
 楼主| 发表于 2015-8-20 15:03:04 | 显示全部楼层
回复 2# icfbicfb
里面有些DRC错误一直解决不了。TG=thick gate layer   PC=POLY   RX=ODcheck GRTG267_HV
(((NW touching TG) touching (PC over RX)) not over DNmust be tied down by the time M1 is complete.
valid tie down 1 : pdiff in NW is connected to ndiff in substrate by m1
valid tie down 2:  ndiff in NW (ntap) is connected to ndiff in substrate by m1( or straddle NW edge)
valid tie down 3 : ndiff/pdiff in NW is connected to ptap in substrate by m1( or pdiff straddles NW edge
这个错误不知怎么下手   版主大大了解吗?
 楼主| 发表于 2015-8-20 15:07:38 | 显示全部楼层
回复 2# icfbicfb
这是我在rule文件中找到的关于这一条rule的 定义
   // TG267_HV//
//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        x_nw_to_tie_1 = ((NW NOT GRLOGIC) OR (NW INTERACT BB)) INTERACT gate
        x_nw_to_tie   = NW INTERACT x_nw_to_tie_1
        x_optionnal_nw_to_tie = NW INTERACT (((NW NOT GRLOGIC) OR (NW INTERACT BB)) NOT INTERACT gate)
// First possible tie down for GR267
// H18REV5
        x_ndiff_for_267_td1 = ndiff NOT (NW OR (DN OR (BB OR (BFMOAT OR RXHV))))
        //x_ndiff_for_267_td1 = ndiff NOT (NW OR (PI OR (BB OR BFMOAT)))
        x_pdiff_in_nwell = (pdiff AND NW) NOT PC
        x_ndiff_in_nwell = (ndiff AND NW) NOT PC
CONNECT pcop_res M1 BY ca_all
CONNECT rxop_res M1 BY ca_all
CONNECT M1 x_ndiff_for_267_td1 BY ca_all
CONNECT M1 x_ndiff_in_nwell BY ca_all
CONNECT x_ndiff_in_nwell x_ndiff_for_267_td1
CONNECT M1 x_pdiff_in_nwell BY ca_all
        x_valid_267_td1 = NET AREA RATIO x_pdiff_in_nwell x_ndiff_for_267_td1 > 0
// Second possible tie down for GR267
// H18REV5
// DN / RXHV
        //x_ndiff_for_267_td2_1 = (ndiff OUTSIDE (NW OR (PI OR (BB OR BFMOAT))))
        //                        OR (((ndiff CUT NW) NOT NW) OUTSIDE (NW OR (PI OR (BB OR BFMOAT))))
        //x_ndiff_for_267_td2_2 = (ndiff NOT ((PI OR BB) OR BFMOAT)) CUT NW
        x_ndiff_for_267_td2_1 = (ndiff OUTSIDE (NW OR (DN OR (BB OR (BFMOAT OR RXHV)))))
                                OR (((ndiff CUT NW) NOT NW) OUTSIDE (NW OR (DN OR (BB OR (BFMOAT OR RXHV)))))
        x_ndiff_for_267_td2 = x_ndiff_for_267_td2_1 OR x_ndiff_for_267_td2_2
CONNECT M1 x_ndiff_for_267_td2 BY ca_all
CONNECT RX x_ndiff_for_267_td2
CONNECT x_ndiff_for_267_td2 x_ndiff_in_nwell
        x_valid_267_td2 = NET AREA RATIO x_ndiff_in_nwell x_ndiff_for_267_td2 > 0
// Third possible tie down for GR267
// H18REV5
// DN/RXHV
        //x_sxcont_for_267_td3_1 = sxcont NOT (NW OR (PI OR (BB OR BFMOAT)))
        //x_sxcont_for_267_td3_2 = (pdiff NOT (PI OR (BB OR BFMOAT))) CUT NW
        x_sxcont_for_267_td3_1 = sxcont NOT (NW OR (DN OR (BB OR (BFMOAT OR RXHV))))
        x_sxcont_for_267_td3_2 = (pdiff NOT (DN OR (BB OR (BFMOAT OR RXHV)))) CUT NW
        x_diff_in_nwell = x_pdiff_in_nwell OR x_ndiff_in_nwell
        x_sxcont_for_267_td3 = x_sxcont_for_267_td3_1 OR x_sxcont_for_267_td3_2
CONNECT M1 x_sxcont_for_267_td3 BY ca_all
CONNECT RX x_sxcont_for_267_td3
CONNECT M1 x_diff_in_nwell BY ca_all
CONNECT x_sxcont_for_267_td3 x_diff_in_nwell
        x_valid_267_td3 = NET AREA RATIO x_diff_in_nwell x_sxcont_for_267_td3 > 0
// AMS : not over DN
x_nwtg_to_tie = ((NW INTERACT TG) INTERACT gate) NOT DN
CONNECT NW x_valid_267_td1
CONNECT NW x_valid_267_td2
CONNECT NW x_valid_267_td3
CONNECT NW PI
CONNECT x_nwtg_to_tie x_valid_267_td1
CONNECT x_nwtg_to_tie x_valid_267_td2
CONNECT x_nwtg_to_tie x_valid_267_td3
CONNECT x_nwtg_to_tie PI
GRTG267_HV {@ (((NW touching TG) touching (PC over RX)) not over DN
         @ must be tied down by the time M1 is complete.
         @ valid tie down 1 : pdiff in NW is connected to ndiff in substrate by m1
         @ valid tie down 2:  ndiff in NW (ntap) is connected to ndiff in substrate by m1( or straddle NW edge)
         @ valid tie down 3 : ndiff/pdiff in NW is connected to ptap in substrate by m1( or pdiff straddles NW edge)
         NET AREA RATIO x_nwtg_to_tie OVER x_valid_267_td1 x_valid_267_td2 x_valid_267_td3 == 0 }
 楼主| 发表于 2015-8-21 10:38:33 | 显示全部楼层
版主在吗
发表于 2015-8-21 19:24:12 | 显示全部楼层
不是特别清楚,发layout版面看看吧
GMT+8, 2025-12-20 01:12 , Processed in 0.020547 second(s), 7 queries , Gzip On, Redis On.
