楼主: 午后乐天派
[求助] sta里面怎么报出false_path的原因
 楼主| 发表于 2015-7-31 09:45:47 | 显示全部楼层
回复 10# voiluce
    NAME
       timing_report_unconstrained_paths
              Specifies  if  PrimeTime searches for unconstrained paths or not
              when you use the report_timing or get_timing_paths command.
TYPE
       Boolean
DEFAULT
       false
DESCRIPTION
       When this variable is set to FALSE (the default), the report_timing and
       get_timing_paths  commands  search  only for constrained paths. It runs
       much faster if there are lots of unconstrained paths in the design, but
       you are not interested in these unconstrained paths.
只在report_timing or get_timing_paths时有效,并不能报出false_path的来源。
发表于 2015-7-31 09:59:10 | 显示全部楼层
report_timing -exceptions
发表于 2015-7-31 10:44:12 | 显示全部楼层
搂主有点诚意好不好,把条件约束和路径贴出来啊
 楼主| 发表于 2015-7-31 13:35:38 | 显示全部楼层
 楼主| 发表于 2015-7-31 13:39:46 | 显示全部楼层
汗点瓷 发表于 2015-7-31 10:44
    只能贴出report,没有约束啊。我要是知道哪条约束导致它false_path,就不用来这里问了。
decoder/reg_38_a_reg[0]/D CKN(fall) SYS_CLK   hold      untested  false_paths
decoder/reg_38_a_reg[0]/D CKN(fall) SYS_CLK   setup     untested  false_paths
decoder/reg_38_a_reg[0]/RN(rise)
                             CKN(fall) SYS_CLK   recovery  untested  false_paths
                             CKN(fall) SYS_CLK   removal   untested  false_paths
decoder/reg_38_a_reg[1]/D CKN(fall) SYS_CLK   hold      untested  false_paths
decoder/reg_38_a_reg[1]/D CKN(fall) SYS_CLK   setup     untested  false_paths
decoder/reg_38_a_reg[1]/RN(rise)
发表于 2020-12-22 11:05:38 | 显示全部楼层
decoder/re ...
这个report是用什么命令报出来的呢?
GMT+8, 2025-12-30 14:22 , Processed in 0.017885 second(s), 3 queries , Gzip On, Redis On.
