查看: 9506|回复: 10
[求助] voltus 生成Macro Power Grid Library时报错误的问题
发表于 2015-7-23 10:48:21 | 显示全部楼层 |阅读模式
大家好!
    我在voltus (v15.10-p001_1版本)上练习voltus_ESD_13.2的lab库,在生成Macro Power Grid Library时,
报如下错误:
Begin Processing Spice Netlist
/public/cadence/SSV15.10/tools.lnx86/spectre/bin/64bit/spectre: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
** ERROR: (VOLTUS_LSIM-5221): generate_pg_library : Device model processing
failed. This may be caused due to error in spectre simulation. Verify
spectre setup.
----------------------   FATAL   ----------------------
** ERROR: (VOLTUS_LGEN-3205): generate_pg_library failed to calculate
current distribution due to errors in VOLTUS_LIBRARY_SIMULATOR. Please
review VOLTUS_LIBRARY_SIMULATOR log "./stdcells_pgv/voltus_libsim.log"
which contain exact cause of the problem.
Finished PGV Library Generator at 10:13:32 07/23/2015 (cpu=0:00:06, real=0:00:32, peak mem=500.79MB)
Current Voltus IC Power Integrity Solution resource usage: (total cpu=0:00:15, real=0:01:34, mem=411.94MB)
1
请问这个问题该如何解决呢?谢谢!
发表于 2015-9-8 18:40:43 | 显示全部楼层
应该是你的spectre有问题
Device model processing failed. This may be caused due to error in spectre simulation. Verify
spectre setup.
发表于 2015-9-9 17:25:14 | 显示全部楼层
工具没装好:
不是写了么
发表于 2019-4-11 16:37:21 | 显示全部楼层
遇到了类似的问题,求高手解答
发表于 2019-4-11 22:48:59 | 显示全部楼层
求高手解答
发表于 2023-1-9 17:29:55 | 显示全部楼层
liuhaib11 发表于 2015-9-8 18:40
应该是你的spectre有问题
Device model processing failed. This may be caused due to error in spectre s ...
请问voltus生成单元库pgv时,怎么设置tcl能产生tap node distance 为n/a, 而工具默认设置为50um ;
发表于 2023-3-31 14:46:47 | 显示全部楼层
请问您是否了解生成PGV时显示warn:number of taps is zeo for non-filler cell是什么意思?
发表于 2023-4-13 16:13:44 | 显示全部楼层
有解决吗
发表于 2023-4-17 18:13:43 | 显示全部楼层
没有,工具默认 生成distance node : 50 ,还没解决
发表于 2023-4-17 18:14:34 | 显示全部楼层
有没有定义filler的单元类型?
GMT+8, 2025-11-18 03:06 , Processed in 0.021488 second(s), 5 queries , Gzip On, Redis On.
