查看: 2195|回复: 0
[讨论] 数字电路的综合问题
发表于 2015-7-9 22:12:37 | 显示全部楼层 |阅读模式
本人在用服务器做DAC的数字电路部分,发现在综合前RTL的功能验证正确,但综合后,生成的网表文件通过了  形式验证,做PT时,有很多违例,vcs动态仿真结果页只有输入信号,输出信号几乎都为NA值(不知道这是什么值);之后直接用综合后的网表文件画了版图,进行了vcs后仿,结果却是对的Report : timing
        -path_type full
        -delay_type min
        -max_paths 1
        -transition_time
Design : top_interpolator
Version: C-2009.06-SP3
Date   : Thu Jul  9 21:39:49 2015
  Startpoint: reset (input port)
  Endpoint: CIC/cha_zhi3/count_reg
               (removal check against rising-edge clock clk)
  Path Group: **async_default**
  Path Type: min
  Point                                          Trans       Incr       Path
  clock (input port clock) (rise edge)                       0.00       0.00
  clock network delay (ideal)                                0.00       0.00
  input external delay                                       0.00       0.00 r
  reset (in)                                      0.00       0.00       0.00 r
  CIC/reset (ling_jie)                            0.00       0.00       0.00 r
  CIC/cha_zhi3/reset (cha_ling_zhi2)              0.00       0.00       0.00 r
  CIC/cha_zhi3/count_reg/SN (JKFFSX1)             0.00       0.00       0.00 r
  data arrival time                                                     0.00
  clock clk (rise edge)                           0.00       0.00       0.00
  clock network delay (ideal)                                1.00       1.00
  clock uncertainty                                          1.75       2.75
  CIC/cha_zhi3/count_reg/CK (JKFFSX1)                                   2.75 r
  library removal time                                       0.17       2.92
  data required time                                                    2.92
  slack (VIOLATED)                                                     -2.92
Startpoint: CIC/cha_zhi3/chazhi_hou_reg[0]
               (rising edge-triggered flip-flop clocked by clk)
  Endpoint: CIC/delay_line2_0_reg[0]
  Path Group: clk
  Path Type: min
  CIC/cha_zhi3/chazhi_hou_reg[0]/CK (DFFRHQX1)
                                                 -0.01       0.00       1.00 r
  CIC/cha_zhi3/chazhi_hou_reg[0]/Q (DFFRHQX1)     0.00       0.32 *     1.32 f
  CIC/cha_zhi3/U31/Y (DLY4X1)                     0.00       1.06 *     2.38 f
  CIC/cha_zhi3/U30/Y (CLKBUFXL)                   0.00       0.31 *     2.70 f
  CIC/cha_zhi3/chazhi_hou[0] (cha_ling_zhi2)      0.00       0.00 *     2.70 f
  CIC/delay_line2_0_reg[0]/D (DFFRHQX1)           0.00       0.00 *     2.70 f
  data arrival time                                                     2.70
  CIC/delay_line2_0_reg[0]/CK (DFFRHQX1)                                2.75 r
  library hold time                                         -0.05 *     2.70
  data required time                                                    2.70
  data arrival time                                                    -2.70
  slack (MET)                                                           0.00
  Startpoint: filter_in[1]
               (input port)
  Endpoint: Compensantor/delay_reg[0][1]
               (rising edge-triggered flip-flop clocked by clk16)
  Path Group: clk16
  Path Type: min
  input external delay                                       0.00       0.00 f
  filter_in[1] (in)                               0.06       0.02       0.02 f
  Compensantor/filter_in[1] (compensantor)        0.00       0.00 *     0.02 f
  Compensantor/delay_reg[0][1]/D (DFFRHQX1)       0.00       0.00 *     0.02 f
  data arrival time                                                     0.02
  clock clk16 (rise edge)                         0.00       0.00       0.00
  Compensantor/delay_reg[0][1]/CK (DFFRHQX1)                            0.00 r
  library hold time                                         -0.04 *    -0.04
  data required time                                                   -0.04
  data arrival time                                                    -0.02
  slack (MET)                                                           0.05
  Startpoint: CIC/cha_zhi2/chazhi_hou_reg[0]
               (rising edge-triggered flip-flop clocked by clk2)
  Endpoint: CIC/delay_line1_0_reg[0]
  Path Group: clk2
  Path Type: min
  clock clk2 (rise edge)                          0.00       0.00       0.00
  CIC/cha_zhi2/chazhi_hou_reg[0]/CK (DFFRHQX1)
                                                 -0.01       0.00       0.00 r
  CIC/cha_zhi2/chazhi_hou_reg[0]/Q (DFFRHQX1)     0.00       0.32 *     0.32 f
  CIC/cha_zhi2/chazhi_hou[0] (cha_ling_zhi1)      0.00       0.00 *     0.32 f
  CIC/delay_line1_0_reg[0]/D (DFFRHQX1)           0.00       0.00 *     0.32 f
  data arrival time                                                     0.32
  CIC/delay_line1_0_reg[0]/CK (DFFRHQX1)                                0.00 r
  data arrival time                                                    -0.32
  slack (MET)                                                           0.37
  Startpoint: CIC/cha_zhi1/chazhi_hou_reg[0]/CK
               (internal path startpoint clocked by clk4)
  Endpoint: CIC/delay_line0_0_reg[0]
               (rising edge-triggered flip-flop clocked by clk4)
  Path Group: clk4
  Path Type: min
  clock clk4 (rise edge)                          0.00       0.00       0.00
  CIC/cha_zhi1/chazhi_hou_reg[0]/CK (DFFRHQX1)
                                                 -0.01       0.00       0.00 r
  CIC/cha_zhi1/chazhi_hou_reg[0]/Q (DFFRHQX1)     0.00       0.32 *     0.32 f
  CIC/cha_zhi1/chazhi_hou[0] (cha_ling_zhi0)      0.00       0.00 *     0.32 f
  CIC/delay_line0_0_reg[0]/D (DFFRHQX1)           0.00       0.00 *     0.32 f
  CIC/delay_line0_0_reg[0]/CK (DFFRHQX1)                                0.00 r
  slack (MET)                                                           0.37
  Startpoint: Compensantor/com_filter_out_reg[0]
  Endpoint: Halfband/halfband_in_reg[0]
               (rising edge-triggered flip-flop clocked by clk8)
  Path Group: clk8
  Path Type: min
  Compensantor/com_filter_out_reg[0]/CK (DFFRHQX1)
                                                 -0.01       0.00       0.00 r
  Compensantor/com_filter_out_reg[0]/Q (DFFRHQX1)
                                                  0.00       0.33 *     0.33 f
  Compensantor/com_filter_out[0] (compensantor)
                                                  0.00       0.00 *     0.33 f
  Halfband/com_filter_out[0] (halfband)           0.00       0.00 *     0.33 f
  Halfband/U668/Y (AND2X2)                        0.00       0.19 *     0.52 f
  Halfband/halfband_in_reg[0]/D (DFFRHQXL)        0.00       0.00 *     0.52 f
  data arrival time                                                     0.52
  clock clk8 (rise edge)                          0.00       0.00       0.00
  Halfband/halfband_in_reg[0]/CK (DFFRHQXL)                             0.00 r
  library hold time                                          0.03 *     0.03
  data required time                                                    0.03
  data arrival time                                                    -0.52
  slack (MET)                                                           0.49
即版图画好后,再做静态时序仿真时,会有一个违例,其他都正常,但我直接进行vcs动态仿真时,波形却可以正常输出。那我前面综合后仿真不通过,以及静态时序仿真PT有多个违例,还要不要处理,本人刚由模拟电路转到数字电路,很多都不熟悉,特别是DC综合这部分,希望各位能帮帮忙,谢谢了!
GMT+8, 2025-12-26 07:41 , Processed in 0.018978 second(s), 5 queries , Gzip On, Redis On.
