楼主: sonis
cmos data converters for communications",亚马逊上价值超一百英镑的好书
发表于 2006-10-9 15:20:57 | 显示全部楼层
good book
发表于 2006-10-9 15:21:12 | 显示全部楼层
good book
发表于 2006-10-11 12:12:48 | 显示全部楼层
评价尚可!
发表于 2006-12-12 20:35:52 | 显示全部楼层
Thanks!
发表于 2006-12-12 21:05:25 | 显示全部楼层
谢谢了!
怎么上传大于2M的附件的啊!
发表于 2006-12-13 13:15:31 | 显示全部楼层
谢谢,这本超值的好书。关键是只要下载一次!
发表于 2006-12-13 13:16:47 | 显示全部楼层
Reviews
Synopsis
This work explains in detail how to derive data converter requirements for a given communication system (baseband, passband, and multi-carrier systems). The authors also review CMOS data converter architectures and discuss their suitability for communications. The rest of the book is dedicated to high-performance CMOS data converter architecture and circuit design. Pipelined ADCs, parallel ADCs with an improved passive sampling technique, and oversampling ADCs are the focus for ADC architectures, while current-steering DAC modelling and implementation are the focus for DAC architectures. The principles of the switched-current and the switched-capacitor techniques are reviewed and their applications to crucial functional blocks such as multiplying DACs and integrators are detailed. CM OS Data Converters for Communications distinguishes itself from other data converter books by emphasizing system-related aspects of the design and frequency-domain measures. The book outlines the design of the basic building blocks such as operational amplifiers, comparators, and reference generators with emphasis on the practical aspects. To operate analogue circuits at a reduced supply voltage, special circuit techniques are needed. Low-voltage techniques are also discussed in this book. This work can be used as a reference book by analogue circuit designers to understand the data converter requirements for communication applications. It can also be used by telecommunication system designers to understand the difficulties of certain performance requirements on data converters.
发表于 2006-12-14 11:20:39 | 显示全部楼层
Forget to say thanks
发表于 2006-12-14 11:23:32 | 显示全部楼层
发表于 2006-12-14 12:51:40 | 显示全部楼层
is that possible?
GMT+8, 2025-12-30 02:23 , Processed in 0.022073 second(s), 4 queries , Gzip On, Redis On.
