查看: 4760|回复: 18
Design of MixedVoltage I/O Buffers With LowVoltage ThinOxide CMOS(M.D Ker)
发表于 2007-5-5 10:22:06 | 显示全部楼层 |阅读模式
Overview and Design of Mixed-Voltage I/O Buffers
With Low-Voltage Thin-Oxide CMOS Transistors
Ming-Dou Ker, Senior Member, IEEE,
Abstract—Overview on the prior designs of the mixed-voltage
I/O buffers is provided in this work. A new 2.5/5-V mixed-voltage
I/O buffer realized with only thin gate-oxide devices is proposed.
The new proposed mixed-voltage I/O buffer with simpler dynamic
n-well bias circuit and gate-tracking circuit can prevent the
undesired leakage current paths and the gate-oxide reliability
problem, which occur in the conventional CMOS I/O buffer. The
new mixed-voltage I/O buffer has been fabricated and verified in
a 0.25- m CMOS process to serve 2.5/5-V I/O interface. Besides,
another 2.5/5-V mixed-voltage I/O buffer without the subthreshold
leakage problem for high-speed applications is also presented in
this work. The speed, power consumption, area, and noise among
these mixed-voltage I/O buffers are also compared and discussed.
The new proposed mixed-voltage I/O buffers can be easily scaled
toward 0.18- um (or below) CMOS processes to serve other
mixed-voltage I/O interfaces, such as 1.8/3.3-V interface.
Index Terms—Gate-oxide reliability, gate-tracking circuit, interface,
mixed-voltage I/O buffer.
Ker_SLChen_CSTsai_TCAS1_Sep_2006.pdf
1.37 MB, 下载次数: 272 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-5-6 23:06:19 | 显示全部楼层
:D
发表于 2007-5-7 22:16:45 | 显示全部楼层
thank you
发表于 2008-3-22 09:46:15 | 显示全部楼层
谢谢楼主了,这个东西真的很好
发表于 2008-6-16 12:46:05 | 显示全部楼层
Thank!
头像被屏蔽
发表于 2008-6-16 12:58:22 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-6-16 13:26:53 | 显示全部楼层
is paper
发表于 2010-5-21 08:47:56 | 显示全部楼层
XXX
XXX
发表于 2010-5-21 08:50:27 | 显示全部楼层
XXX
XXX
发表于 2010-5-26 14:26:56 | 显示全部楼层
xie xie lou zhu
GMT+8, 2025-12-31 09:27 , Processed in 0.023963 second(s), 8 queries , Gzip On, Redis On.
