查看: 2519|回复: 0
★Asp.net如何连接SQL Server2000数据库★
发表于 2004-7-24 11:59:19 | 显示全部楼层 |阅读模式
     大家好,以下是有关ASP.net连接SQL Server2000数据库的例程,
     在这里和大家分享一下:
     Asp.net连接SQL Server2000数据库例程详解:
     <%@ Import Namespace="System.Data" %>
     <%@ Import NameSpace="System.Data.SqlClient" %>
     <script laguage="VB" runat="server">
     sub page_load(sender as Object,e as EventArgs)
     Dim myConnection As SqlConnection
     Dim myCommand As SqlCommand
     Dim ds as DataSet
     '1.connect to sql server
     myConnection = New SqlConnection( "server=localhost;database=Pubs;uid=ueytjdf;pwd=doekdf" )
     myConnection.Open()
     la1.text="Connection Opened!"
     '2.Create a table
     myCommand = New SqlCommand( "CREATE TABLE [test] ([id] [int] IDENTITY (1, 1) NOT NULL ,[name]
     [char] (10) COLLATE Chinese_PRC_CI_AS NULL ,[sex] [char] (10) COLLATE Chinese_PRC_CI_AS NULL
     )", myConnection )
     myCommand.ExecuteNonQuery()
     la2.text="New table created!"
     '2 添加纪录
     myCommand = New SqlCommand( "Insert into [test] (name,sex) values( '黄志文','男' )",
     myConnection )
     la3.text="New Record Inserted!"
     '3 更新数据
     myCommand = New SqlCommand( "UPDATE [test] SET name='Smith' where name='李明'", myConnection )
     la4.text="Record Updated!"
     '4 删除数据
     myCommand = New SqlCommand( "delete from [test] where name='Smith'", myConnection )
     la5.text="Record Deleted!"
     '5 用DataGrid显示数据
     myCommand = New SqlCommand( "select * from [test]", myConnection )
     MyDataGrid.DataSource=myCommand.ExecuteReader()
     MyDataGrid.DataBind()
     end sub
     </script>
     <html>
     <body>
     <asp:label id="la1" runat="server" /><br>
     <asp:label id="la2" runat="server" /><br>
     <asp:label id="la3" runat="server" /><br>
     <asp:label id="la4" runat="server" /><br>
     <asp:label id="la5" runat="server" /><br>
     <ASPataGrid id="MyDataGrid" runat="server"
     BorderColor="black"
     BorderWidth="1"
     GridLines="Both"
     CellPadding="3"
     CellSpacing="0"
     Font-Name="Verdana"
     Font-Size="10pt"
     HeaderStyle-BackColor="#aaaadd"
     AlternatingItemStyle-BackColor="#eeeeee"
     </aspataGrid>
     </body>
     </html>
     推荐空间:
     ●商务型C 1600元/年
     独立500网站空间 ,同时支持 ASP, ASP.NET;
     提供50M的SQLSERVER2000的数据库存,支持ACCESS数据库
     送800MB邮箱邮箱
     现在购买送.com+.cn的域名
     ●虚拟专用C型机 4000元/年
     3000M的网站空间,同时支持 ASP, ASP.NET
     支持SQLSERVER2000/access数据库,数据库空间不限
      现在购买送.com+.cn的域名
     ★中国国家顶级域名全面降价!只需180元/年!!!!
     ★ 凡是企业在本公司购满300元以上,均可获得.CN域名!!!
     详情请见: http://www.now.net.cn/host
     全球免费咨询电话,请点击 http://www.now.net.cn/customer/moreline.net
     欢迎您访问 http://www.now.net.cn/host
     Q Q在线咨询:45031657 108786612
     TEL:0756-2282587 2281070
GMT+8, 2025-12-23 19:45 , Processed in 0.014920 second(s), 8 queries , Gzip On, Redis On.
