查看: 4845|回复: 12
运算放大器性能研究(麻省理工资料)
发表于 2007-4-20 20:28:06 | 显示全部楼层 |阅读模式
给大家一个麻省理工关于运放的资料
OPAperformance research.pdf
175.39 KB, 下载次数: 88 , 下载积分: 资产 -2 信元, 下载支出 2 信元
运放研究
发表于 2007-4-22 23:01:26 | 显示全部楼层
不值!!!
头像被屏蔽
发表于 2007-8-14 22:42:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-8-15 09:53:40 | 显示全部楼层
看不到啊~~~
发表于 2007-8-15 11:07:17 | 显示全部楼层
不错
发表于 2007-8-15 15:27:29 | 显示全部楼层
下了,不过英文的,费劲.。。。
发表于 2008-2-4 01:20:05 | 显示全部楼层
thanks
发表于 2008-2-4 22:28:44 | 显示全部楼层
太少了!!
发表于 2008-2-4 22:32:00 | 显示全部楼层
DEPARTMENT OF ELECTRICAL ENGINEERING AND COMPUTER SCIENCE
MASSACHUSETTS INSTITUTE OF TECHNOLOGY
CAMBRIDGE, MASSACHUSETTS 02139
6.101 Introductory Analog Electronics Laboratory
Laboratory No. 4
比较不实用!!!
发表于 2008-2-4 22:33:19 | 显示全部楼层
READING ASSIGNMENT
In this laboratory, you will investigate the performance of operational amplifiers in simple circuit configurations. We will discuss various aspects of operational amplifier behavior in class. In addition, you should have read at least the Operational Amplifiers class reading assignments in the class outline under section 7.
Objective: At last! The Bigtime!! Op-amps!!! You will be using the LM741, which is one of the earliest of popular operational amplifiers, the LF356 which is a precision JFET-input op-amp with very low input bias current, wider open-loop bandwidth, higher slew rate, etc., the LM6152, a dual rail-to-rail op-amp, and the LM311 comparator.
GMT+8, 2025-12-27 13:10 , Processed in 0.022391 second(s), 8 queries , Gzip On, Redis On.
