查看: 2539|回复: 0
求助~4位微处理器中存储模块的程序问题
发表于 2007-4-13 16:00:49 | 显示全部楼层 |阅读模式
我的程序如下,compile就会报错说无源,但我程序应该没问题啊,拜托帮忙看下 ~~~
LIBRARY IEEE;
USE IEEE .std_logic_1164.ALL;
USE IEEE .std_logic_arith.ALL;
ENTITY ureg IS
        PORT (clk : IN std_logic;
              reset: IN std_logic;
              en  : IN std_logic;
              d   : IN unsigned (3 downto 0);
              q   : BUFFER unsigned(3 downto 0));
END ureg;
ARCHITECTURE rtl OF ureg IS
BEGIN
      PROCESS (clk,reset)
      BEGIN
             IF(reset='1') THEN
                q <=( OTHERS =>'0');
             ELSIF(clk'event AND clk='1') THEN
                IF (en='1') THEN
                    q<=d;
                ELSE
                    q<=q;
                END IF;
             END IF;
       END PROCESS;
END rtl;
LIBRARY IEEE;
PACKAGE mnemonics IS
        CONSTANT aq : std_logic_vector (2 downto 0) := "000";
        CONSTANT ab : std_logic_vector (2 downto 0) := "001";
        CONSTANT zq : std_logic_vector (2 downto 0) := "010";
        CONSTANT zb : std_logic_vector (2 downto 0) := "011";
        CONSTANT za : std_logic_vector (2 downto 0) := "100";
        CONSTANT da : std_logic_vector (2 downto 0) := "101";
        CONSTANT dq : std_logic_vector (2 downto 0) := "110";
        CONSTANT dz : std_logic_vector (2 downto 0) := "111";
        CONSTANT add : std_logic_vector (2 downto 0) := "000";
        CONSTANT subr : std_logic_vector (2 downto 0) := "001";
        CONSTANT subs : std_logic_vector (2 downto 0) := "010";
        CONSTANT orrs : std_logic_vector (2 downto 0) := "011";
        CONSTANT andrs : std_logic_vector (2 downto 0) := "100";
        CONSTANT notrs : std_logic_vector (2 downto 0) := "101";
        CONSTANT exor : std_logic_vector (2 downto 0) := "110";
        CONSTANT exnor : std_logic_vector (2 downto 0) := "111";
        CONSTANT qreg : std_logic_vector (2 downto 0) := "000";
        CONSTANT nop : std_logic_vector (2 downto 0) := "001";
        CONSTANT rama : std_logic_vector (2 downto 0) := "010";
        CONSTANT ramf : std_logic_vector (2 downto 0) := "011";
        CONSTANT ramqd : std_logic_vector (2 downto 0) := "100";
        CONSTANT ramd : std_logic_vector (2 downto 0) := "101";
        CONSTANT ramqu : std_logic_vector (2 downto 0) := "110";
        CONSTANT ramu : std_logic_vector (2 downto 0) := "111";
END PACKAGE mnemonics;
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_arith.ALL;
USE WORK.mnemonics.ALL;
ENTITY  ram_regs IS
              reset    : IN std_logic;
              a, b     : IN unsigned (3 downto 0);
              f       : IN unsigned (3 downto 0);
              dest_ctl  : IN std_logic_vector (2 downto 0);
              ram0,ram3: INOUT std_logic;
              ad, bd    : BUFFER unsigned (3 downto 0));
END ram_regs;
ARCHITECTURE ram_regs_arch OF ram_regs IS
     COMPONENT ureg
             GENERIC (size : integer:=4);
                   en  : IN std_logic;
                   d   : IN unsigned (size-1 downto 0);
                   q   : BUFFER unsigned(size-1 downto 0));
        END COMPONENT ureg;
        SIGNAL ram_en   : std_logic;
        SIGNAL data      :unsigned (3 downto 0);
        SIGNAL en       : std_logic_vector ( 15 downto 0);
        TYPE ram_array IS ARRAY ( 15 downto 0) OF unsigned ( 3 downto 0);
        SIGNAL ab_data   : ram_array;
BEGIN
        WITH dest_ctl SELECT
              ram_en <= '0' WHEN qreg | nop,
                        '1'WHEN OTHERS;
        enable_proc: PROCESS (b)
        BEGIN
               Decode:FOR I IN 0 TO 15 LOOP
                     IF (conv_integer (b) = i) THEN
                         En (i) <= ram_en;
                     ELSE
                         En (i) <= '0';
                     END IF;
               END LOOP decode;
        END PROCESS;
             data <= (f (2 downto 0) & ram0 ) WHEN ramqu | ramu,
                     (ram3 & f(3 downto 1)) WHEN ramqd | ramd,
                     F WHEN rama | ramf,
                     "----" WHEN OTHERS;
        register_generator: FOR I IN 15 downto 0 generate
                Uregx : ureg
                          GENERIC MAP(4)
                          PORT MAP (clk,reset, en(i), data, ab_data(i));
        END GENERATE register_generator;
        ad <= ab_data (conv_integer(a));
        bd <= ab_data (conv_integer(b));
        Ram3 <= f(3) WHEN (dest_ctl =ramqu OR dest_ctl =ramu ) ELSE 'Z';
        Ram0 <= f(0) WHEN (dest_ctl =ramqd OR dest_ctl =ramd ) ELSE 'Z';
END ram_regs_arch;
GMT+8, 2025-12-15 22:50 , Processed in 0.022948 second(s), 8 queries , Gzip On, Redis On.
