查看: 4954|回复: 2
ucos-ii 276在往s3c2410板子上移植OSTaskStkInit 函数具体怎么改啊达人给指导一下啊
发表于 2007-4-12 10:06:40 | 显示全部楼层 |阅读模式
OS_STK *OSTaskStkInit (void (*task)(void *pd), void *pdata, OS_STK *ptos, INT16U opt)
    OS_STK *stk;
    opt    = opt;                           /* 'opt' is not used, prevent warning                      */
    stk    = ptos;                          /* Load stack pointer                                      */
    *(stk) = (OS_STK)task;                  /* Entry Point                                             */
    *(--stk) = (INT32U)0;                   /* r14(lr)                                                 */
    *(--stk) = (INT32U)0;                   /* r12                                                     */
    *(--stk) = (INT32U)0;                   /* r11                                                     */
    *(--stk) = (INT32U)0;                   /* r10                                                     */
    *(--stk) = (INT32U)0;                   /* r9                                                      */
    *(--stk) = (INT32U)0;                   /* r8                                                      */
    *(--stk) = (INT32U)0;                   /* r7                                                      */
    *(--stk) = (INT32U)0;                   /* r6                                                      */
    *(--stk) = (INT32U)0;                   /* r5                                                      */
    *(--stk) = (INT32U)0;                   /* r4                                                      */
    *(--stk) = (INT32U)0;                   /* r3                                                      */
    *(--stk) = (INT32U)0;                   /* r2                                                      */
    *(--stk) = (INT32U)0;                   /* r1                                                      */
    *(--stk) = (INT32U)pdata;               /* r0 : argument                                           */
    *(--stk) = (INT32U)(SVCMODE|0x0);       /* PSR                                                     */
    *(--stk) = (INT32U)(SVCMODE|0x0);       /* SPSR                                                    */
        return (stk);
发表于 2009-5-6 08:54:26 | 显示全部楼层
thanks!
发表于 2010-4-26 21:32:57 | 显示全部楼层
谢谢楼主!
GMT+8, 2025-12-30 16:12 , Processed in 0.026441 second(s), 7 queries , Gzip On, Redis On.
