查看: 19937|回复: 69
Charge-Pump reducing current mismatch in DLLs and
发表于 2007-4-11 21:42:25 | 显示全部楼层 |阅读模式
Conventional CMOS charge-pump circuits havesome current mismatch problems. The current mismatch induces a phase offset which deteriorates the performance of Up PLLs or DLLs. This paper investigates causes of current mismatch of conventional CMOS charge-pump and proposes new charge-pump circuits to reduce the current mismatch. The Vpb DLL with proposed charge-pump is simulated in a 0.18 um CMOS process.
01693061.pdf
3.42 MB, 下载次数: 624 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-4-12 08:44:34 | 显示全部楼层
好文章真多,工程师真要命
发表于 2007-4-12 08:57:10 | 显示全部楼层
好像打不开???
发表于 2007-4-12 16:12:24 | 显示全部楼层
好像确实是打不开,楼主还是及早检查一下吧!
发表于 2007-8-29 01:34:01 | 显示全部楼层
ding!!!!!!!!!!!!!!
发表于 2007-8-29 08:43:48 | 显示全部楼层
发表于 2007-8-29 11:32:59 | 显示全部楼层
ggggggggggggggggggg
ggggggggggggggggggg
发表于 2007-8-29 12:34:24 | 显示全部楼层
确实是打不开
发表于 2007-9-29 22:06:26 | 显示全部楼层
thank you
发表于 2007-10-3 17:26:35 | 显示全部楼层
thank you
GMT+8, 2025-12-21 12:18 , Processed in 0.026414 second(s), 6 queries , Gzip On, Redis On.
