查看: 5957|回复: 3
[求助] modelsim中出现错误 Error: (vsim-3063)
发表于 2015-6-8 18:52:34 | 显示全部楼层 |阅读模式
Error: (vsim-3063) H:/verilogtext/fft_ctrl/fft_top.v(65): Port 'clock' not found in the connected module (2nd connection
 楼主| 发表于 2015-6-8 21:55:20 | 显示全部楼层
** Warning: (vsim-3017) H:/verilogtext/fft_ctrl/fft_toptest.v(51): [TFMPC] - Too few port connections. Expected 12, found 10.
#         Region: /fft_toptest/m4
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_toptest.v(51): [TFMPC] - Missing connection for port 'sink_real'.
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_toptest.v(51): [TFMPC] - Missing connection for port 'sink_image'.
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(38): [PCDPC] - Port size (12 or 12) does not match connection size (1) for port 'cache_ctrl_addr'. The port definition is at: H:/verilogtext/fft_ctrl/fft_ctrl.v(1).
#         Region: /fft_toptest/m4/m0
# ** Warning: (vsim-3017) H:/verilogtext/fft_ctrl/fft_top.v(56): [TFMPC] - Too few port connections. Expected 18, found 16.
#         Region: /fft_toptest/m4/m1
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (18 or 18) does not match connection size (1) for port 'sink_real'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(32).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (18 or 18) does not match connection size (1) for port 'sink_imag'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(33).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (2 or 2) does not match connection size (1) for port 'source_error'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(37).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (6 or 6) does not match connection size (1) for port 'source_exp'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(41).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (18 or 18) does not match connection size (1) for port 'source_real'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(42).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(56): [PCDPC] - Port size (18 or 18) does not match connection size (1) for port 'source_imag'. The port definition is at: H:/verilogtext/fft_ctrl/fft_bb.v(43).
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_top.v(56): [TFMPC] - Missing connection for port 'inverse'.
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_top.v(56): [TFMPC] - Missing connection for port 'sink_error'.
# ** Warning: (vsim-3017) H:/verilogtext/fft_ctrl/fft_top.v(65): [TFMPC] - Too few port connections. Expected 6, found 5.
#         Region: /fft_toptest/m4/m2
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(65): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'address'. The port definition is at: H:/verilogtext/fft_ctrl/srams_bb.v(35).
# ** Error: (vsim-3063) H:/verilogtext/fft_ctrl/fft_top.v(65): Port 'clock' not found in the connected module (2nd connection).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(65): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'data'. The port definition is at: H:/verilogtext/fft_ctrl/srams_bb.v(36).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(65): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'q'. The port definition is at: H:/verilogtext/fft_ctrl/srams_bb.v(40).
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_top.v(65): [TFMPC] - Missing connection for port 'inclock'.
# ** Warning: (vsim-3722) H:/verilogtext/fft_ctrl/fft_top.v(65): [TFMPC] - Missing connection for port 'outclock'.
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(74): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'address'. The port definition is at: H:/verilogtext/fft_ctrl/sram_bb.v(35).
#         Region: /fft_toptest/m4/m3
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(74): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'data'. The port definition is at: H:/verilogtext/fft_ctrl/sram_bb.v(37).
# ** Warning: (vsim-3015) H:/verilogtext/fft_ctrl/fft_top.v(74): [PCDPC] - Port size (8 or 8) does not match connection size (1) for port 'q'. The port definition is at: H:/verilogtext/fft_ctrl/sram_bb.v(39).
发表于 2015-6-9 10:55:14 | 显示全部楼层
testbench例化,里面少了   .clock  (clock),
 楼主| 发表于 2015-6-10 23:47:30 | 显示全部楼层
回复 3# fpgaqin
谢谢啊
GMT+8, 2025-12-15 06:52 , Processed in 0.022679 second(s), 5 queries , Gzip On, Redis On.
