查看: 12364|回复: 25
零极点分析
发表于 2007-4-10 21:14:31 | 显示全部楼层 |阅读模式
大家欣赏一下老外的电路分析方法
零极点分析.pdf
1.02 MB, 下载次数: 381 , 下载积分: 资产 -2 信元, 下载支出 2 信元
零极点分析.pdf
发表于 2007-4-11 09:56:32 | 显示全部楼层
Design Techniques for Cascoded CMOS
Op Amps with Improved PSRR and
Common-Mode Input Range
Abstract —Intemafly compensated CMOS op amps have ~en widely
used in sampled-analog signaf processing applications over the past several
years; however, the popular two-stage op amp suffers from poor ac power
supply rejection to one of the power rails. This paper presents two circuits
that overcome the PSRR problems of the earlier amplifiec one for virtual
ground applications such as switched-capacitor integrators, and the other
for buffer applications requiring wide common-mode input range. Small
signal [email=an@ysis]an@ysis[/email] is developed for the open loop and PSRR responses of the
two amplifiers. In addition, design guidelines are suggested and test results
are presented.
发表于 2007-4-11 10:16:18 | 显示全部楼层
xixexie!
发表于 2007-4-11 11:18:27 | 显示全部楼层
这个也叫零极点分析啊,
物非所值吧。
真正厉害的零极点分析,还得看根轨迹图。
发表于 2007-5-2 12:13:43 | 显示全部楼层
感觉很一般
发表于 2007-5-2 20:50:14 | 显示全部楼层
it 's a good data
but i have not enough money
thanks of your sharing!!
头像被屏蔽
发表于 2007-5-4 19:19:32 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-6-21 23:00:59 | 显示全部楼层
kankan
发表于 2007-6-23 00:38:24 | 显示全部楼层
这个还是不下了,书上还是比较齐全的!
发表于 2007-12-4 10:37:56 | 显示全部楼层
看看有没用
GMT+8, 2025-11-14 03:16 , Processed in 0.021980 second(s), 6 queries , Gzip On, Redis On.
