查看: 2418|回复: 1
[求助] ddr3 IP核生成过程中master bank是什么意思?怎么选的?
发表于 2015-6-3 10:59:37 | 显示全部楼层 |阅读模式
Master bank:
Except System Clock bank, any bank in a given column of banks which are only within the vicinity can be selected as Master bank
A Master bank will always have VRN/VRP pins unused. Due to this in a given bank VRN/VRP pins will be reserved if it is selected as Master bank
All the Data group banks in the given column acts as Slave banks if a Master bank is selected in that column. The same is given in the generated UCF file 。
A master bank must be selected for each column if DCI cascade is to be used.
If VRN/VRP pins are utilized for pin allocation in a bank, the DCI cascading
feature must be applied to support DCI. In this case, a master bank must be
selected.
不知道为什么ml605的选了bank25,bank26不行吗?
发表于 2015-6-5 13:25:20 | 显示全部楼层
bank25是不是那一列bank的中间bank?7系列DDR控制器选择的bank必须在同一列,地址控制bank必须是中间bank,估计你选用的器件有类似的要求,可以查看下MIG手册。
GMT+8, 2025-12-22 00:58 , Processed in 0.017379 second(s), 5 queries , Gzip On, Redis On.
