查看: 2357|回复: 0
[招聘] 美企 招Staff Digital Design Engineer -上海
发表于 2015-6-1 11:17:40 | 显示全部楼层 |阅读模式
以下职位,若有兴趣,麻烦发简历至  sherry_luyin@126.com   我们会及时联系您,谢谢!
Position:Staff Digital Design Engineer (Memory Interface Products)
Job Description:
-Work with analog/digital ASIC design team for new product development;
-Design, implementation, and verification of digital in mixed-signal ICs;
-Perform backend digital design (logic synthesis, formal check, define design constraints for place & route, perform timing closure, DFT);
-Support system, test & product team with chip debugging, failure analysis, characterizations and product release efforts.
Qualification Requirements:
-Master degree or above in EE or related field;
-At least 5 years experience in digital design;
-Have rich experience at high speed digital design;
- Projects tape out experience with 65nm process, 40nm or 28nm preferred;
-Experience as project leader is a plus;
-Good knowledge in semi-conductor and transistor level;
-Good language and communication skills in English for both spoken and written;
-Highly organized and self motivated;
-Ability to work well with teammates (locally or remotely) in a fast-paced professional environment.
艾迪悌科技(上海)有限公司 ( IDT-Shanghai ) ,是IDT公司在中国境内的唯一全资子公司,是IDT最为重要的海外研发中心。公司创立于1997年,拥有数名世界一流的业内专家顾问,一百四十多名员工,技术处于世界先进行列,产品涵盖了消费类芯片CID, VFD, PC Clock;通信类芯片Codec, E1/T1, IMA, WAN PLL, Switch以及网络类Bridgeport, Fastport等多种芯片。目前,公司正在开展的项目有PC Clock、AMB、HDMI、Ethernet PHY、SerDes、WAN PLL等。 公司地址:宜山路900号     公司网站:http://www.idt.com/
GMT+8, 2025-12-26 03:34 , Processed in 0.019668 second(s), 8 queries , Gzip On, Redis On.
