查看: 7399|回复: 7
[求助] clock gating
发表于 2015-5-30 01:15:45 | 显示全部楼层 |阅读模式
我在dv使用insert_clock_gating指令將register合成clock gating
但不知道為什麼switch power變高了?
照理說合成clock gating後,power要下降
但我完全反過來,請問這是什麼原因造成的?
发表于 2015-5-30 07:30:27 | 显示全部楼层
report有点问题吧,贴出来看看
 楼主| 发表于 2015-5-30 12:34:40 | 显示全部楼层
current_design [get_designs Reg1_32bit]
Current design is 'Reg1_32bit'.
{Reg1_32bit}
insert_clock_gating
Warning: Clock gating insertion with insert_clock_gating is deprecated and will be removed in a future release; instead use the compile -gate_clock command. (PWR-729)
Information: Performing clock-gating on design Reg1_32bit
# Latch based CG (default)
set_clock_gating_style -sequential_cell latch
Current clock gating style....
Sequential cell: latch
Minimum register bank size: 3
Minimum bank size for enhanced clock gating: 6
Maximum fanout: unlimited
Setup time for clock gate: 0.000000
Hold time for clock gate: 0.000000
Clock gating circuitry (positive edge): and
Clock gating circuitry (negative edge): or
Note: inverter between clock gating circuitry
       and (negative edge) register clock pin.
Control point insertion: none
Control signal for control point: scan_enable
Observation point insertion: false
Observation logic depth: 5
1
# Latch free CG
set_clock_gating_style -sequential_cell none
Warning: Using scan_enable with latch-free clock gating may cause DRC violations during test insertion. (PWR-379)
Sequential cell: none
Clock gating circuitry (positive edge): or
Clock gating circuitry (negative edge): and
1
# integrated CG
set_clock_gating_style -negative_edge_logic "integrated"
Error: The library cell required for use as an integrated clock-gating cell does not exist in the libraries specified.  The required attribute is latch_negedge.  (PWR-191)
Warning: The clock-gating style was not changed. (PWR-132)
0
#set multi stages clock gating
set_clock_gating_style -num_stages 2 -sequential_cell latch
Maximum number of stages: 2
以上是我的report,請幫我看看,有點不太了解錯在哪裡?
发表于 2015-6-1 18:05:51 | 显示全部楼层
report_power出来看看
发表于 2015-6-1 18:13:21 | 显示全部楼层
学习了
发表于 2015-6-2 09:39:37 | 显示全部楼层
power cell本身也是带free run 的clock的,看你cg结构设计如何,不是说加上一定省电的。
发表于 2016-11-16 21:00:24 | 显示全部楼层
谢谢。
发表于 2016-11-16 21:22:39 | 显示全部楼层
dc报power就是个笑话,cg的activity标不上去的
GMT+8, 2025-10-7 05:12 , Processed in 0.021503 second(s), 7 queries , Gzip On, Redis On.
