查看: 5397|回复: 6
EKV MOSFET verilogA model
发表于 2015-5-20 13:31:06 | 显示全部楼层 |阅读模式
MOSFET verilogA
Share:
ExamplesVerilog-A implementation of the EPFL-EKV v2.6 model (long channel)
[size=-1]Verilog-A code for the long channel EKV MOSFET model
`include "std.va"
`include "const.va"
// * EKV MOS model (long channel) based on version 2.6 rev.15
// * Function name : ekv26_dc_long for verilog-a implementation
// * The model documetation: http://legwww.epfl.ch/ekv
module ekv(d,g,s,b);
// Node definitions
        inout           d,g,s,b ;   // external nodes
        electrical      d,g,s,b ;   // external nodes
//*** Local variables
real x, VG, VS, VD, VGprime, VP;
real beta, n, iff, ir, Ispec, Id;
//*** model parameter definitions
parameter real L      =  10E-6  from[0.0:inf];
parameter real W      =  10E-6  from[0.0:inf];
//***  Threshold voltage
//     substrate effect parameters (long-channel)
parameter real VTO    =  0.5    from[0.0:inf];
parameter real GAMMA  =  0.7    from[0.0:inf];
parameter real PHI    =  0.5    from[0.2:inf];
//***  Mobility parameters (long-channel)
parameter real KP     =  20E-6   from[0.0:inf];
parameter real THETA  =  50.0E-3 from[0.0:inf];
analog begin // EKV v2.6 long-channel
VG = V(g, b); VS = V(s, b); VD = V(d, b);
// Effective gate voltage (33)
VGprime = VG - VTO + PHI + GAMMA * sqrt(PHI);
// Pinch-off voltage (34)
VP = VGprime - PHI - GAMMA
   * (sqrt(VGprime+(GAMMA/2.0)*(GAMMA/2.0))-(GAMMA/2.0));
// Slope factor (39)
n = 1.0 + GAMMA / (2.0*sqrt(PHI + VP + 4.0*$vt));
// Mobility equation (58), (64)
beta = KP * (W/L) * (1.0/(1.0 + THETA * VP));
// forward (44) and reverse (56) currents
x=(VP-VS)/$vt; iff = (ln(1.0+exp( x /2.0)))*(ln(1.0+exp( x /2.0)));
x=(VP-VD)/$vt; ir  = (ln(1.0+exp( x /2.0)))*(ln(1.0+exp( x /2.0)));
// Specific current (65)
Ispec = 2 * n * beta * $vt * $vt;
// Drain current (66)
Id = Ispec * (iff - ir);
// Branch contributions to EKV v2.6 model (long-channel)
I(d,s) <+ Id;
end // analog
endmodule
[size=-1]Netlist to test Verilog-A EKV model
* EKV long channel MOSFET Model - using Verilog-A
.verilog  "ekv.va"
vd  1  0 3
vg  2  0 5
vb  4  0 0
xekv  1 2 0 4 ekv L=20E-6 W=20E-6
.dc vd 0 5 0.1
.end
who have bsim4 verilogA  ??
Compact Modeling of 0.35um SOI CMOS.pdf (229.56 KB , 下载次数: 32 )
Compact Modeling of Cryogenic cmos circuit use verilogA.pdf (467 KB , 下载次数: 44 )
verilogA compact model Grabinski_MOS-AK_India.pdf (2.81 MB , 下载次数: 46 )
发表于 2015-5-21 16:27:27 | 显示全部楼层
EKV MOSFET model looks so simple!!!
 楼主| 发表于 2015-5-21 18:47:41 | 显示全部楼层
回复 2# judung
    no use ekv ..
不 知道誰使用過 ekv model  ?
那間foundary 是使用 ekv
发表于 2017-6-14 21:44:20 | 显示全部楼层
VerilogA建模型为什么资料这么少呀?她究竟有没有市场呀?
发表于 2018-1-9 20:10:25 | 显示全部楼层
发表于 2018-2-28 19:51:44 | 显示全部楼层
thank you
发表于 2023-7-14 15:51:11 | 显示全部楼层
thanks
GMT+8, 2025-12-26 11:35 , Processed in 0.022561 second(s), 5 queries , Gzip On, Redis On.
