查看: 6128|回复: 6
[求助] netlistProcedure介绍
发表于 2015-5-11 14:26:47 | 显示全部楼层 |阅读模式
悬赏500资产已解决
求一个netlistProcedure的文档,介绍netlistProcedure用法和写法等等。
例如ansCdlCompPrim _andCdlCompParamPrim...
不要Cadence的SKILL文档和CDF文档,那个到处能找得到。
最佳答案
查看完整内容
defun(ABbnNetlistProc (inst) let((formatter netlister bulk sigs) ;---------------------------------------------------------------- ; Get hold of the formatter and netlister objects ;---------------------------------------------------------------- formatter=nlGetFormatter(inst) netlister=nlGetNetlister(formatter) nlPrintInstComments(formatter inst) ...
发表于 2015-5-11 14:26:48 | 显示全部楼层
        nlPrintIndentString(netlister)
        nlPrintInstName(formatter inst)
        ; Print the standard signals. Can't use nlPrintInstSignals
        ; because the parentheses would be around the terminals in
        ; the termOrder, and not include the bulk node
        sigs=nlGetSignalList(inst)
        nlPrintString(netlister " (" car(sigs))
        foreach(sig cdr(sigs)
            nlPrintString(netlister " " sig)
        ) ; foreach
        ; Get the bn parameter and output that as the connection, if
        ; it is set
        bulk=nlGetParamStringValue(inst "bn")
        when(member(bulk '("D" "G" "S"))
            bulk=nlGetTerminalSignalName(inst bulk)
        when(bulk
            nlPrintString(netlister " " bulk)
        ; Write out the close parenthesis, now that the bulk is written
        nlPrintString(netlister ")")
        nlPrintModelName(formatter inst)
        nlPrintInstParameters(formatter inst)
自己再修改修改
 楼主| 发表于 2016-1-20 14:19:01 | 显示全部楼层
回复 2# jimipage
   有没有关于netlistProcedure的Manual?
发表于 2016-9-4 11:21:26 | 显示全部楼层
Gooood job.
发表于 2018-5-21 21:10:34 | 显示全部楼层
实用的资料
发表于 2018-6-20 07:51:32 | 显示全部楼层
回复 3# superguy
    Component Description Format User
Guide
Product Version 6.1.4
February 2011
cdfuser.pdf (2.67 MB , 下载次数: 64 )
发表于 2024-5-11 19:28:21 | 显示全部楼层
peterlin2010 发表于 2018-6-20 07:51
回复 3# superguy
学习
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 04:23 , Processed in 0.015442 second(s), 5 queries , Gzip On, Redis On.
