查看: 2859|回复: 3
[求助] [求助]新学的FPGA,写了个SPI的状态机,有什么不对吗?仿真似乎总有问题。
发表于 2015-4-17 22:22:12 | 显示全部楼层 |阅读模式
拜托各位达人了
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY SPI3578 IS
GENERIC(
N_WAITCLK  : INTEGER := 10;
N_DELAYCLK : INTEGER := 4
PORT(
ICLK
: IN  STD_LOGIC;
IRESET
: IN  STD_LOGIC;
IEN     : IN  STD_LOGIC;
SPICLK
: OUT STD_LOGIC;
SDO
    : IN STD_LOGIC;
SDI
: OUT STD_LOGIC;
CS
: OUT STD_LOGIC;
DATAIN
: IN
STD_LOGIC_VECTOR(15 DOWNTO 0);
DATAOUT  : OUT
END ENTITY;
ARCHITECTURE BEHAVIOR OF SPI3578 IS
TYPE SPI_STATE IS (S0_IDLE,S1_REP,S2_PLACE,S3_RECIVE,S4_DELAY);
SIGNAL CURRENT_STATE,NEXT_STATE  : SPI_STATE;
SIGNAL CNT ,NDLAY  : INTEGER RANGE 0 TO  127;
SIGNAL BITL
:INTEGER RANGE 0 TO 15;
SIGNAL SCLK
: STD_LOGIC := '0';
SIGNAL TX_DATA
: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL RX_DATA
BEGIN
STATE_RENEW
ROCESS(ICLK,IRESET)
BEGIN
IF RISING_EDGE(ICLK)
THEN
IF (IRESET ='0')
THEN
CURRENT_STATE
<= S0_IDLE;
SPICLK
<= '0';
CS
<= '1';
ELSE
CURRENT_STATE
<= NEXT_STATE;
    END IF;
END IF;
END PROCESS;
STATE_CREATROCESS(CURRENT_STATE,IEN,ICLK)
BEGIN
CASE (CURRENT_STATE) IS
WHEN S0_IDLE
IF IEN = '1' THEN
NEXT_STATE <= S0_IDLE;
CNT <=  0;
CS  <= '1';
ELSE
NEXT_STATE
<= S1_REP;
END IF;
WHEN  S1_REP
IF CNT <= N_WAITCLK  THEN
CNT <= CNT + 1;
NEXT_STATE <= S1_REP;
ELSE
NEXT_STATE <= S2_PLACE;
BITL <= 0;
END IF;
WHEN  S2_PLACE
SDI  <= TX_DATA(15-BITL);
SCLK <= NOT SCLK;
SPICLK
SCLK;
NEXT_STATE <= S3_RECIVE;
WHEN  S3_RECIVE
TX_DATA(15-BITL)<= SDO;
SCLK <= NOT SCLK;
SPICLK
SCLK;
IF BITL
<= 14
THEN
BITL
<= BITL + 1;
ELSE
NEXT_STATE <= S4_DELAY;
END IF;
WHEN  S4_DELAY
IF NDLAY  <=  N_DELAYCLK   THEN
NEXT_STATE <=S4_DELAY;
NDLAY
NDLAY +1;
ELSE
END IF;
WHEN OTHERS
=> NULL;
END CASE;
END PROCESS;
--SPICLK
SCLK;
END  BEHAVIOR   ;
 楼主| 发表于 2015-4-17 22:26:00 | 显示全部楼层
CNT <= CNT + 1;
ELSE
BITL <= 0;
END IF;
这块似乎有问题,process里边不加clk,就执行不下去。
所以,如果 当前状态和下一状态都是 S1_REP,是不是触发不了状态更新的操作
 楼主| 发表于 2015-4-17 22:30:13 | 显示全部楼层
[img] 1111.jpg [/img]
谢谢诸位
发表于 2015-4-18 00:59:00 | 显示全部楼层
不看别的,有这么多红线,说明有很多信号被驱动乱掉了,或者是没有被驱动,在复位信号后,自己设计的逻辑一定不能有未知量
GMT+8, 2025-12-14 21:32 , Processed in 0.017380 second(s), 5 queries , Gzip On, Redis On.
