查看: 14835|回复: 15
[求助] VCS DUMP FSDB 求助
发表于 2015-4-16 22:42:25 | 显示全部楼层 |阅读模式
在虚拟机上面装了VCS2014.03和NOVAS2014.03,然后VCS可以跑,VERDI也能打开,但是在dump fsdb的时候出现了一下的warning
[MaZifa@Colin work]$ ./simv
Chronologic VCS simulator copyright 1991-2014
Contains Synopsys proprietary information.
Compiler version I-2014.03; Runtime version I-2014.03;  Apr 16 22:50 2015
*Verdi3* Loading libsscore_vcs201403.so
*Verdi3* : Enable Parallel Dumping.
FSDB Dumper for VCS, Release Verdi3_I-2014.03, Linux, 02/10/2014
(C) 1996 - 2014 by Synopsys, Inc.
*  WARNING -                                                          *
*  The FSDB dumper support is still in beta stage for the simulator   *
*  version that you are running. For any abnormal behavior, please    *
*  contact Synopsys support for assistance.                           *
*Verdi3* FSDB WARNING: The FSDB file already exists. Overwriting the FSDB file may crash the programs that are using this file.
*Verdi3* : Create FSDB file 'test.fsdb'
*Verdi3* : Begin traversing the scope (tb_iic), layer (0).
*Verdi3* : End of traversing.
看起来是说dump波形的时候license不够,我就想知道dump波形是不是还需要license的,,,感觉好奇怪。。。。
跑vcs和verdi的命令如下:
#PROJECT PATH                             #
PROJECT_DIR = /mnt/hgfs/lin_win/qyg002_debug/iic_test
TB_DIR   = ${PROJECT_DIR}/testbench
RTL_DIR  = $[PROJECT_DIR]/ip/miic
CASE_DIR = ${PROJECT_DIR}/testcase
TB_LIST  = -f ${TB_DIR}/iic_tb.f
RTL_LIST = -f ${TB_DIR}/iic.f
CASE_LIST = ${CASE_DIR}/tb_iic.v
#DEBUSSY EVN DEFINE                       #
DEBUSSY_DIR = /usr/novas/2014.03/share/PLI/VCS/LINUX
DEBUSSY_OPTIONS += -debug_pp -P ${DEBUSSY_DIR}/novas.tab ${DEBUSSY_DIR}/pli.a +define+DUMPFSDB
#VCS EVN DEFINE                           #
TIMESCALE = 1ns/1ps
SIM_OPTIONS += -sverilog
SIM_OPTIONS += +v2k
SIM_OPTIONS += -override_timescale=${TIMESCALE}
SIM_OPTIONS += +access+rw
run_vcs :
        vcs ${DEBUSSY_OPTIONS} \
                        ${CASE_LIST} \
                        ${TB_LIST} \
                        ${RTL_LIST} \
                        ${SIM_OPTIONS} \
                        -l test.log
        ./simv
run_debussy :
        verdi +v2k +access+rw ${CASE_LIST} \
                        ${TB_LIST} \
                        ${RTL_LIST} \ &
求教,,,万分感激。。。。
发表于 2015-4-21 16:42:05 | 显示全部楼层
回复 1# mazifa
Warning没提到license的问题啊?
 楼主| 发表于 2015-4-21 22:40:13 | 显示全部楼层
回复 2# nativeda
感觉这个就是。。。
发表于 2015-4-23 22:07:32 | 显示全部楼层
内容看不出来有问题啊
发表于 2015-4-24 08:35:52 | 显示全部楼层
换个低点版本的vcs
发表于 2015-5-22 09:10:19 | 显示全部楼层
你可以先dump到vcd,然后再用verdi转到fsdb呀
发表于 2015-7-12 16:16:14 | 显示全部楼层
mark@#¥!%!
发表于 2015-7-13 12:00:18 | 显示全部楼层
I don't see any problem
发表于 2015-7-13 12:01:07 | 显示全部楼层
I dont see problem
发表于 2015-7-13 12:01:50 | 显示全部楼层
i see problem
GMT+8, 2025-12-18 22:55 , Processed in 0.435233 second(s), 5 queries , Gzip On, Redis On.
