查看: 2120|回复: 2
[求助] LDO补偿
发表于 2015-4-8 21:34:45 | 显示全部楼层 |阅读模式
请教各位一般的补偿电路分为哪几种?在LDO的设计中应该怎么设计补偿电路
发表于 2015-4-11 03:35:05 | 显示全部楼层
It depends on the design is capless or is using external cap, and where to position the dominant pole vs non-dominant poles. There are many other design metrics need to be considered beside stability.
All compensation techniques for 2-stage OpAmp are working for LDO except the ouput POLE can move a few orders with respect to variation of load current.
Check out the book below, and it should help.
http://www.amazon.com/Analog-Low-Dropout-Regulators-Electronic-Engineering/dp/0071608931/ref=sr_1_1?ie=UTF8&qid=1428694846&sr=8-1&keywords=ldo
发表于 2015-6-3 21:45:47 | 显示全部楼层
回复 2# jake10000
    您好,请问有没有输出极点在片外的,但无片外电容的ldo结构
GMT+8, 2025-12-20 10:42 , Processed in 0.015292 second(s), 6 queries , Gzip On, Redis On.
