查看: 2898|回复: 3
[求助] ICC做完CTS之后clock出现fanout违例
发表于 2015-4-8 08:27:59 | 显示全部楼层 |阅读模式
如题,做完CTS之后出现如下violate
CTS 过程的log文件如下:
不明白为什么做完了CTS还会有这么多高扇出的clock net
发表于 2015-4-8 09:43:42 | 显示全部楼层
set_clock_tree_options -max_fanout 设了么,
如果没有timing/slew/cap violation 也无所谓的,
 楼主| 发表于 2015-4-8 15:46:03 | 显示全部楼层
谢谢前辈的回复,我明白了
 楼主| 发表于 2015-4-8 15:47:23 | 显示全部楼层
做LVS的时候报错,我用的是smic13的工艺库
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         fully_sar_logic.lvs.report
LAYOUT NAME:              /home/szpku/highbury_v1.1/modules/ecg_adc/worbench/verification/lvs/fully_sar_logic.sp ('fully_sar_logic')
SOURCE NAME:              /home/szpku/highbury_v1.1/modules/ecg_adc/worbench/fully_sar_logic.cdl ('fully_sar_logic')
RULE FILE:                /home/szpku/highbury_v1.1/modules/ecg_adc/worbench/verification/lvs/_SmicSPM7PR12R_cal013_mixRF_sali_p1mtx_1233_V2.6_2P.lvs_XRC_
CREATION TIME:            Wed Apr  8 11:09:03 2015
CURRENT DIRECTORY:        /home/szpku/highbury_v1.1/modules/ecg_adc/worbench/verification/lvs
USER NAME:                chenc
CALIBRE VERSION:          v2010.3_37.26    Mon Oct 4 16:17:31 PDT 2010
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of nets.
  Error:    Different numbers of instances.
  Error:    Connectivity errors.
  Warning:  Ambiguity points were found and resolved arbitrarily.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      fully_sar_logic               fully_sar_logic
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD" "SAVDD?" "?VDD?" "?VCC?" "?vcc?" "?vdd?"
   LVS GROUND NAME                        "VSS" "SAVSS?" "?gnd?" "?GND?" "?VSS?" "?vss?"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       NO
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       YES
   LVS EXPAND UNBALANCED CELLS            YES
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   LVS SPICE MULTIPLIER NAME              "M" "MR"
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE SCALE X PARAMETERS           NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     50
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   LVS FILTER UNUSED OPTION               AB RC RE RG
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // Device Type Map
   LVS DEVICE TYPE                        RESISTOR "rnwaa_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnwsti_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpdif_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rndif_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rppo_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rppo_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnpo_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnpo_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpdifsab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rndifsab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rhrpo_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rhrpo_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "ralpa_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm1_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm2_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm3_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm4_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm5_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm8_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "ralpa_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rndifsab_ckt_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpdifsab_ckt_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_ckt_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_ckt_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rhrpo_ckt_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_ckt_rf_3t" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_ckt_rf_3t" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rhrpo_ckt_rf_3t" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rtm2_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "n12_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "p12_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "n33_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "p33_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw12_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw33_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwhvt12_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwlvt12_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw12_4t_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw33_4t_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwhvt12_4t_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwlvt12_4t_ckt" SOURCE LAYOUT
   // Reduction
   LVS REDUCE SERIES MOS                  NO
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 YES
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           YES
   LVS REDUCE PARALLEL CAPACITORS         YES
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
   LVS REDUCE  pvar12_ckt  PARALLEL [ TOLERANCE LR 0 WR 0 ]
   LVS REDUCE  pvar33_ckt  PARALLEL [ TOLERANCE LR 0 WR 0 ]
   LVS REDUCE  C(mim15)  PARALLEL
   LVS REDUCE  pvar12_ckt_rf  PARALLEL [ TOLERANCE LR 0 WR 0 ]
   LVS REDUCE  pvar33_ckt_rf  PARALLEL [ TOLERANCE LR 0 WR 0 ]
   LVS REDUCTION PRIORITY                 PARALLEL
   // Filter
   LVS FILTER  D(parasitic_rwd)  OPEN
   LVS FILTER  D(parasitic_dnwd)  OPEN
   LVS FILTER  D(parasitic_nwd)  OPEN
   // Trace Property
   TRACE PROPERTY  mn(n12)  l l 5
   TRACE PROPERTY  mn(n12)  w w 5
   TRACE PROPERTY  mn(nt12)  l l 5
   TRACE PROPERTY  mn(nt12)  w w 5
   TRACE PROPERTY  mn(nlvt12)  l l 5
   TRACE PROPERTY  mn(nlvt12)  w w 5
   TRACE PROPERTY  mn(nhvt12)  l l 5
   TRACE PROPERTY  mn(nhvt12)  w w 5
   TRACE PROPERTY  mp(p12)  l l 5
   TRACE PROPERTY  mp(p12)  w w 5
   TRACE PROPERTY  mp(plvt12)  l l 5
   TRACE PROPERTY  mp(plvt12)  w w 5
   TRACE PROPERTY  mp(phvt12)  l l 5
   TRACE PROPERTY  mp(phvt12)  w w 5
   TRACE PROPERTY  mn(n33)  l l 5
   TRACE PROPERTY  mn(n33)  w w 5
   TRACE PROPERTY  mn(nt33)  l l 5
   TRACE PROPERTY  mn(nt33)  w w 5
   TRACE PROPERTY  mp(p33)  l l 5
   TRACE PROPERTY  mp(p33)  w w 5
   TRACE PROPERTY  n12_mis_ckt  l l 5
   TRACE PROPERTY  n12_mis_ckt  w w 5
   TRACE PROPERTY  n33_mis_ckt  l l 5
   TRACE PROPERTY  n33_mis_ckt  w w 5
   TRACE PROPERTY  p12_mis_ckt  l l 5
   TRACE PROPERTY  p12_mis_ckt  w w 5
   TRACE PROPERTY  p33_mis_ckt  l l 5
   TRACE PROPERTY  p33_mis_ckt  w w 5
   TRACE PROPERTY  dnw12_ckt  w w 5
   TRACE PROPERTY  dnw12_ckt  l l 5
   TRACE PROPERTY  dnw33_ckt  w w 5
   TRACE PROPERTY  dnw33_ckt  l l 5
   TRACE PROPERTY  dnwlvt12_ckt  w w 5
   TRACE PROPERTY  dnwlvt12_ckt  l l 5
   TRACE PROPERTY  dnwhvt12_ckt  w w 5
   TRACE PROPERTY  dnwhvt12_ckt  l l 5
   TRACE PROPERTY  dnw12_4t_ckt  w w 5
   TRACE PROPERTY  dnw12_4t_ckt  l l 5
   TRACE PROPERTY  dnw33_4t_ckt  w w 5
   TRACE PROPERTY  dnw33_4t_ckt  l l 5
   TRACE PROPERTY  dnwlvt12_4t_ckt  w w 5
   TRACE PROPERTY  dnwlvt12_4t_ckt  l l 5
   TRACE PROPERTY  dnwhvt12_4t_ckt  w w 5
   TRACE PROPERTY  dnwhvt12_4t_ckt  l l 5
   TRACE PROPERTY  m(c1)  l l 5
   TRACE PROPERTY  m(c1)  w w 5
   TRACE PROPERTY  m(c2)  l l 5
   TRACE PROPERTY  m(c2)  w w 5
   TRACE PROPERTY  pvar12_ckt  wr wr 5
   TRACE PROPERTY  pvar12_ckt  lr lr 5
   TRACE PROPERTY  pvar12_ckt  nf nf 0
   TRACE PROPERTY  pvar33_ckt  wr wr 5
   TRACE PROPERTY  pvar33_ckt  lr lr 5
   TRACE PROPERTY  pvar33_ckt  nf nf 0
   TRACE PROPERTY  d(pdio12)  a a 5
   TRACE PROPERTY  d(plvtdio12)  a a 5
   TRACE PROPERTY  d(phvtdio12)  a a 5
   TRACE PROPERTY  d(ndio12)  a a 5
   TRACE PROPERTY  d(ntdio12)  a a 5
   TRACE PROPERTY  d(nlvtdio12)  a a 5
   TRACE PROPERTY  d(nhvtdio12)  a a 5
   TRACE PROPERTY  d(nwdio)  a a 5
   TRACE PROPERTY  d(rwdio33)  a a 5
   TRACE PROPERTY  d(dnwdio33)  a a 5
   TRACE PROPERTY  d(pdio33)  a a 5
   TRACE PROPERTY  d(ndio33)  a a 5
   TRACE PROPERTY  d(ntdio33)  a a 5
   TRACE PROPERTY  r(rndif_nw)  r r 5
   TRACE PROPERTY  r(rndifsab_nw)  r r 5
   TRACE PROPERTY  mn(npg)  l l 5
   TRACE PROPERTY  mn(npg)  w w 5
   TRACE PROPERTY  mn(npd)  l l 5
   TRACE PROPERTY  mn(npd)  w w 5
   TRACE PROPERTY  mp(pl)  l l 5
   TRACE PROPERTY  mp(pl)  w w 5
   TRACE PROPERTY  mn(npghs)  l l 5
   TRACE PROPERTY  mn(npghs)  w w 5
   TRACE PROPERTY  mn(npdhs)  l l 5
   TRACE PROPERTY  mn(npdhs)  w w 5
   TRACE PROPERTY  mp(plhs)  l l 5
   TRACE PROPERTY  mp(plhs)  w w 5
   TRACE PROPERTY  rnwaa_ckt  w w 5
   TRACE PROPERTY  rnwaa_ckt  l l 5
   TRACE PROPERTY  rnwsti_ckt  w w 5
   TRACE PROPERTY  rnwsti_ckt  l l 5
   TRACE PROPERTY  rpdif_ckt  w w 5
   TRACE PROPERTY  rpdif_ckt  l l 5
   TRACE PROPERTY  rndif_ckt  w w 5
   TRACE PROPERTY  rndif_ckt  l l 5
   TRACE PROPERTY  rppo_ckt  w w 5
   TRACE PROPERTY  rppo_ckt  l l 5
   TRACE PROPERTY  rppo_3t_ckt  w w 5
   TRACE PROPERTY  rppo_3t_ckt  l l 5
   TRACE PROPERTY  rnpo_ckt  w w 5
   TRACE PROPERTY  rnpo_ckt  l l 5
   TRACE PROPERTY  rnpo_3t_ckt  w w 5
   TRACE PROPERTY  rnpo_3t_ckt  l l 5
   TRACE PROPERTY  rpdifsab_ckt  w w 5
   TRACE PROPERTY  rpdifsab_ckt  l l 5
   TRACE PROPERTY  rndifsab_ckt  w w 5
   TRACE PROPERTY  rndifsab_ckt  l l 5
   TRACE PROPERTY  rpposab_ckt  w w 5
   TRACE PROPERTY  rpposab_ckt  l l 5
   TRACE PROPERTY  rpposab_3t_ckt  w w 5
   TRACE PROPERTY  rpposab_3t_ckt  l l 5
   TRACE PROPERTY  rnposab_ckt  w w 5
   TRACE PROPERTY  rnposab_ckt  l l 5
   TRACE PROPERTY  rnposab_3t_ckt  w w 5
   TRACE PROPERTY  rnposab_3t_ckt  l l 5
   TRACE PROPERTY  rhrpo_ckt  w w 5
   TRACE PROPERTY  rhrpo_ckt  l l 5
   TRACE PROPERTY  rhrpo_3t_ckt  w w 5
   TRACE PROPERTY  rhrpo_3t_ckt  l l 5
   TRACE PROPERTY  rtm2_rf  w w 5
   TRACE PROPERTY  rtm2_rf  l l 5
   TRACE PROPERTY  ralpa_rf  w w 5
   TRACE PROPERTY  ralpa_rf  l l 5
   TRACE PROPERTY  r(rnwaa)  w w 5
   TRACE PROPERTY  r(rnwaa)  l l 5
   TRACE PROPERTY  r(rnwsti)  w w 5
   TRACE PROPERTY  r(rnwsti)  l l 5
   TRACE PROPERTY  r(rpdif)  w w 5
   TRACE PROPERTY  r(rpdif)  l l 5
   TRACE PROPERTY  r(rndif)  w w 5
   TRACE PROPERTY  r(rndif)  l l 5
   TRACE PROPERTY  r(rppo)  w w 5
   TRACE PROPERTY  r(rppo)  l l 5
   TRACE PROPERTY  r(rppo_3t)  w w 5
   TRACE PROPERTY  r(rppo_3t)  l l 5
   TRACE PROPERTY  r(rnpo)  w w 5
   TRACE PROPERTY  r(rnpo)  l l 5
   TRACE PROPERTY  r(rnpo_3t)  w w 5
   TRACE PROPERTY  r(rnpo_3t)  l l 5
   TRACE PROPERTY  r(rpdifsab)  w w 5
   TRACE PROPERTY  r(rpdifsab)  l l 5
   TRACE PROPERTY  r(rndifsab)  w w 5
   TRACE PROPERTY  r(rndifsab)  l l 5
   TRACE PROPERTY  r(rpposab)  w w 5
   TRACE PROPERTY  r(rpposab)  l l 5
   TRACE PROPERTY  r(rpposab_3t)  w w 5
   TRACE PROPERTY  r(rpposab_3t)  l l 5
   TRACE PROPERTY  r(rnposab)  w w 5
   TRACE PROPERTY  r(rnposab)  l l 5
   TRACE PROPERTY  r(rnposab_3t)  w w 5
   TRACE PROPERTY  r(rnposab_3t)  l l 5
   TRACE PROPERTY  r(rhrpo)  w w 5
   TRACE PROPERTY  r(rhrpo)  l l 5
   TRACE PROPERTY  r(rhrpo_3t)  w w 5
   TRACE PROPERTY  r(rhrpo_3t)  l l 5
   TRACE PROPERTY  r(rm1)  w w 5
   TRACE PROPERTY  r(rm1)  l l 5
   TRACE PROPERTY  r(rm2)  w w 5
   TRACE PROPERTY  r(rm2)  l l 5
   TRACE PROPERTY  r(rm3)  w w 5
   TRACE PROPERTY  r(rm3)  l l 5
   TRACE PROPERTY  r(ralpa)  w w 5
   TRACE PROPERTY  r(ralpa)  l l 5
   TRACE PROPERTY  r(rm4)  w w 5
   TRACE PROPERTY  r(rm4)  l l 5
   TRACE PROPERTY  r(rm5)  w w 5
   TRACE PROPERTY  r(rm5)  l l 5
   TRACE PROPERTY  r(rm8)  w w 5
   TRACE PROPERTY  r(rm8)  l l 5
   TRACE PROPERTY  ralpa_ckt  w w 5
   TRACE PROPERTY  ralpa_ckt  l l 5
   TRACE PROPERTY  rm1_ckt  w w 5
   TRACE PROPERTY  rm1_ckt  l l 5
   TRACE PROPERTY  rm2_ckt  w w 5
   TRACE PROPERTY  rm2_ckt  l l 5
   TRACE PROPERTY  rm3_ckt  w w 5
   TRACE PROPERTY  rm3_ckt  l l 5
   TRACE PROPERTY  rm4_ckt  w w 5
   TRACE PROPERTY  rm4_ckt  l l 5
   TRACE PROPERTY  rm5_ckt  w w 5
   TRACE PROPERTY  rm5_ckt  l l 5
   TRACE PROPERTY  rm8_ckt  w w 5
   TRACE PROPERTY  rm8_ckt  l l 5
   TRACE PROPERTY  mim15_ckt  l l 5
   TRACE PROPERTY  mim15_ckt  w w 5
   TRACE PROPERTY  n12_ckt_rf  wr wr 5
   TRACE PROPERTY  n12_ckt_rf  lr lr 5
   TRACE PROPERTY  n12_ckt_rf  nf nf 0
   TRACE PROPERTY  dnw12_ckt_rf  wr wr 5
   TRACE PROPERTY  dnw12_ckt_rf  lr lr 5
   TRACE PROPERTY  dnw12_ckt_rf  nf nf 0
   TRACE PROPERTY  p12_ckt_rf  wr wr 5
   TRACE PROPERTY  p12_ckt_rf  lr lr 5
   TRACE PROPERTY  p12_ckt_rf  nf nf 0
   TRACE PROPERTY  n33_ckt_rf  wr wr 5
   TRACE PROPERTY  n33_ckt_rf  lr lr 5
   TRACE PROPERTY  n33_ckt_rf  nf nf 0
   TRACE PROPERTY  dnw33_ckt_rf  wr wr 5
   TRACE PROPERTY  dnw33_ckt_rf  lr lr 5
   TRACE PROPERTY  dnw33_ckt_rf  nf nf 0
   TRACE PROPERTY  p33_ckt_rf  wr wr 5
   TRACE PROPERTY  p33_ckt_rf  lr lr 5
   TRACE PROPERTY  p33_ckt_rf  nf nf 0
   TRACE PROPERTY  pvar12_ckt_rf  wr wr 5
   TRACE PROPERTY  pvar12_ckt_rf  lr lr 5
   TRACE PROPERTY  pvar12_ckt_rf  nf nf 0
   TRACE PROPERTY  pvar33_ckt_rf  wr wr 5
   TRACE PROPERTY  pvar33_ckt_rf  lr lr 5
   TRACE PROPERTY  pvar33_ckt_rf  nf nf 0
   TRACE PROPERTY  pvardio12_ckt_rf  wr wr 5
   TRACE PROPERTY  pvardio12_ckt_rf  lr lr 5
   TRACE PROPERTY  pvardio12_ckt_rf  nf nf 0
   TRACE PROPERTY  pvardio33_ckt_rf  wr wr 5
   TRACE PROPERTY  pvardio33_ckt_rf  lr lr 5
   TRACE PROPERTY  pvardio33_ckt_rf  nf nf 0
   TRACE PROPERTY  rndifsab_ckt_rf  l l 5
   TRACE PROPERTY  rndifsab_ckt_rf  w w 5
   TRACE PROPERTY  rpdifsab_ckt_rf  l l 5
   TRACE PROPERTY  rpdifsab_ckt_rf  w w 5
   TRACE PROPERTY  rnposab_ckt_rf  l l 5
   TRACE PROPERTY  rnposab_ckt_rf  w w 5
   TRACE PROPERTY  rpposab_ckt_rf  l l 5
   TRACE PROPERTY  rpposab_ckt_rf  w w 5
   TRACE PROPERTY  rhrpo_ckt_rf  l l 5
   TRACE PROPERTY  rhrpo_ckt_rf  w w 5
   TRACE PROPERTY  rnposab_ckt_rf_3t  l l 5
   TRACE PROPERTY  rnposab_ckt_rf_3t  w w 5
   TRACE PROPERTY  rpposab_ckt_rf_3t  l l 5
   TRACE PROPERTY  rpposab_ckt_rf_3t  w w 5
   TRACE PROPERTY  rhrpo_ckt_rf_3t  l l 5
   TRACE PROPERTY  rhrpo_ckt_rf_3t  w w 5
   TRACE PROPERTY  ind_rf_t1d5  r r 5
   TRACE PROPERTY  ind_rf_t1d5  n n 0
   TRACE PROPERTY  ind_rf_t2  r r 5
   TRACE PROPERTY  ind_rf_t2  n n 0
   TRACE PROPERTY  ind_rf_t2d5  r r 5
   TRACE PROPERTY  ind_rf_t2d5  n n 0
   TRACE PROPERTY  ind_rf_t3  r r 5
   TRACE PROPERTY  ind_rf_t3  n n 0
   TRACE PROPERTY  ind_rf_t3d5  r r 5
   TRACE PROPERTY  ind_rf_t3d5  n n 0
   TRACE PROPERTY  ind_rf_t4  r r 5
   TRACE PROPERTY  ind_rf_t4  n n 0
   TRACE PROPERTY  ind_rf_t4d5  r r 5
   TRACE PROPERTY  ind_rf_t4d5  n n 0
   TRACE PROPERTY  ind_rf_t5  r r 5
   TRACE PROPERTY  ind_rf_t5  n n 0
   TRACE PROPERTY  ind_rf_t5d5  r r 5
   TRACE PROPERTY  ind_rf_t5d5  n n 0
   TRACE PROPERTY  ind_rf_t6  r r 5
   TRACE PROPERTY  ind_rf_t6  n n 0
   TRACE PROPERTY  ind_rf_t6d5  r r 5
   TRACE PROPERTY  ind_rf_t6d5  n n 0
   TRACE PROPERTY  diff_ind_rf  r r 5
   TRACE PROPERTY  diff_ind_rf  n n 0
   TRACE PROPERTY  diff_ind_3t_rf  r r 5
   TRACE PROPERTY  diff_ind_3t_rf  n n 0
   TRACE PROPERTY  diff_ind_3t_alpa_rf  r r 5
   TRACE PROPERTY  diff_ind_3t_alpa_rf  n n 0
   TRACE PROPERTY  ind_rf_psub_t1d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t1d5  n n 0
   TRACE PROPERTY  ind_rf_psub_t2  r r 5
   TRACE PROPERTY  ind_rf_psub_t2  n n 0
   TRACE PROPERTY  ind_rf_psub_t2d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t2d5  n n 0
   TRACE PROPERTY  ind_rf_psub_t3  r r 5
   TRACE PROPERTY  ind_rf_psub_t3  n n 0
   TRACE PROPERTY  ind_rf_psub_t3d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t3d5  n n 0
   TRACE PROPERTY  ind_rf_psub_t4  r r 5
   TRACE PROPERTY  ind_rf_psub_t4  n n 0
   TRACE PROPERTY  ind_rf_psub_t4d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t4d5  n n 0
   TRACE PROPERTY  ind_rf_psub_t5  r r 5
   TRACE PROPERTY  ind_rf_psub_t5  n n 0
   TRACE PROPERTY  ind_rf_psub_t5d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t5d5  n n 0
   TRACE PROPERTY  ind_rf_psub_t6  r r 5
   TRACE PROPERTY  ind_rf_psub_t6  n n 0
   TRACE PROPERTY  ind_rf_psub_t6d5  r r 5
   TRACE PROPERTY  ind_rf_psub_t6d5  n n 0
   TRACE PROPERTY  diff_ind_rf_psub  r r 5
   TRACE PROPERTY  diff_ind_rf_psub  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_psub  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_psub  n n 0
   TRACE PROPERTY  diff_ind_3t_alpa_rf_psub  r r 5
   TRACE PROPERTY  diff_ind_3t_alpa_rf_psub  n n 0
   TRACE PROPERTY  spi_ind_rf_1p2  r r 5
   TRACE PROPERTY  spi_ind_rf_1p3  r r 5
   TRACE PROPERTY  spi_ind_rf_psub_1p2  r r 5
   TRACE PROPERTY  spi_ind_rf_psub_1p3  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t1  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t1  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t2  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t2  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t3  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t3  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t4  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t4  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t5  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t5  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t6  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t6  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_t7  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_t7  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t1  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t1  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t2  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t2  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t3  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t3  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t4  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t4  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t5  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t5  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t6  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t6  n n 0
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t7  r r 5
   TRACE PROPERTY  rf_3tdiff_1talpa_psub_t7  n n 0
   TRACE PROPERTY  ind_rf_pgs_t1d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t1d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t2  r r 5
   TRACE PROPERTY  ind_rf_pgs_t2  n n 0
   TRACE PROPERTY  ind_rf_pgs_t2d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t2d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t3  r r 5
   TRACE PROPERTY  ind_rf_pgs_t3  n n 0
   TRACE PROPERTY  ind_rf_pgs_t3d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t3d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t4  r r 5
   TRACE PROPERTY  ind_rf_pgs_t4  n n 0
   TRACE PROPERTY  ind_rf_pgs_t4d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t4d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t5d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t5d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_t6  r r 5
   TRACE PROPERTY  ind_rf_pgs_t6  n n 0
   TRACE PROPERTY  ind_rf_pgs_t6d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_t6d5  n n 0
   TRACE PROPERTY  diff_ind_rf_pgs  r r 5
   TRACE PROPERTY  diff_ind_rf_pgs  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t1d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t1d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t2  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t2  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t2d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t2d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t3  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t3  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t3d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t3d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t4  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t4  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t4d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t4d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t5d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t5d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t6  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t6  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t6d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_t6d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t1d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t1d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t2  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t2  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t2d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t2d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t3  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t3  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t3d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t3d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t4  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t4  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t4d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t4d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t5d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t5d5  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t6  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t6  n n 0
   TRACE PROPERTY  ind_rf_pgs_psub_t6d5  r r 5
   TRACE PROPERTY  ind_rf_pgs_psub_t6d5  n n 0
   TRACE PROPERTY  diff_ind_rf_pgs_psub  r r 5
   TRACE PROPERTY  diff_ind_rf_pgs_psub  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t1d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t1d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t2  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t2  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t2d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t2d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t3  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t3  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t3d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t3d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t4  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t4  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t4d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t4d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t5d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t5d5  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t6  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t6  n n 0
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t6d5  r r 5
   TRACE PROPERTY  diff_ind_3t_rf_pgs_psub_t6d5  n n 0
   TRACE PROPERTY  mim15_rf  lr lr 5
   TRACE PROPERTY  mim15_rf  wr wr 5
   TRACE PROPERTY  mim15_shield_rf  lr lr 5
   TRACE PROPERTY  mim15_shield_rf  wr wr 5
   TRACE PROPERTY  mom13_ckt  l l 5
   TRACE PROPERTY  mom13_ckt  n n 0
   TRACE PROPERTY  mom14_ckt  l l 5
   TRACE PROPERTY  mom14_ckt  n n 0
   TRACE PROPERTY  mom24_ckt  l l 5
   TRACE PROPERTY  mom24_ckt  n n 0
   TRACE PROPERTY  mom15_ckt  l l 5
   TRACE PROPERTY  mom15_ckt  n n 0
   TRACE PROPERTY  mom25_ckt  l l 5
   TRACE PROPERTY  mom25_ckt  n n 0
   TRACE PROPERTY  mom35_ckt  l l 5
   TRACE PROPERTY  mom35_ckt  n n 0
   TRACE PROPERTY  mom_ckt_rf  lr lr 5
   TRACE PROPERTY  mom_ckt_rf  nf nf 0
   TRACE PROPERTY  mom_ckt_rf  bm bm 0
   TRACE PROPERTY  mom_ckt_rf  tm tm 0
   TRACE PROPERTY  mom_wips_ckt_rf  lr lr 5
   TRACE PROPERTY  mom_wips_ckt_rf  nf nf 0
   TRACE PROPERTY  mom_wips_ckt_rf  bm bm 0
   TRACE PROPERTY  mom_wips_ckt_rf  tm tm 0
   TRACE PROPERTY  mom_ckt_rf_3t  lr lr 5
   TRACE PROPERTY  mom_ckt_rf_3t  nf nf 0
   TRACE PROPERTY  mom_ckt_rf_3t  bm bm 0
   TRACE PROPERTY  mom_ckt_rf_3t  tm tm 0
   TRACE PROPERTY  mom_wips_ckt_rf_3t  lr lr 5
   TRACE PROPERTY  mom_wips_ckt_rf_3t  nf nf 0
   TRACE PROPERTY  mom_wips_ckt_rf_3t  bm bm 0
   TRACE PROPERTY  mom_wips_ckt_rf_3t  tm tm 0
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         fully_sar_logic
SOURCE CELL NAME:         fully_sar_logic
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:            101       101
Nets:           29212     28977    *
Instances:      31131     29865    *    MN (4 pins)
                 31694     29865    *    MP (4 pins)
                    47         0    *    D (2 pins)
Total Inst:     62872     59730
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:            101       101
Nets:           15576     15442    *
Instances:       2290      2294    *    MN (4 pins)
                  2492      2504    *    MP (4 pins)
                    11        11         AOI_3_1 (5 pins)
                    29        29         OAI_3_1 (5 pins)
                     1         1         OAI_3_3 (7 pins)
                    33        33         SDW3 (4 pins)
                   394       394         SPDW_2_1 (4 pins)
                   271       271         SPDW_2_1_1 (5 pins)
                    98        98         SPDW_2_2 (5 pins)
                    12        12         SPDW_2_2_1 (6 pins)
                    56        56         SPDW_2_2_2 (7 pins)
                   204       204         SPUP_2_1 (4 pins)
                    28        28         SPUP_2_1_1 (5 pins)
                   652       652         SPUP_2_2 (5 pins)
                     4         4         SPUP_2_2_2 (7 pins)
                    33        33         SPUP_3_2 (6 pins)
                   207       207         SMN2 (4 pins)
                     5         5         SMP2 (4 pins)
                   419       419         _bitcoreb (6 pins)
                  7518      7523    *    _invv (4 pins)
                   319       320    *    _invx2v (4 pins)
                    25        24    *    _invx3v (4 pins)
                     3         3         _invx4v (4 pins)
                    11        11         _mx2v (6 pins)
                  1225      1225         _nand2v (5 pins)
                    66        66         _nand3v (6 pins)
                    21        21         _nand4v (7 pins)
                   406       406         _nor2v (5 pins)
                    30        30         _nor3v (6 pins)
                    15        15         _nor4v (7 pins)
                    28        28         _pdw2v (4 pins)
                   271       267    *    _pup2v (4 pins)
                  4346      4346         _sdw2v (4 pins)
                  4020      4020         _smp2v (4 pins)
                   842       842         _tgmb (7 pins)
                    54        54         _xr2v (5 pins)
                    83        81    *    _xra2v (5 pins)
Total Inst:     26522     26537
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net 1567                                                  n4631
       ** missing connection **                                  (SPDW_2_1_1)utput
        XU4278/MN8:d
       ** missing connection **                                  (_smp2v)ut1
        XU4278/MP3:s
       ** missing connection **                                  (_invv):in
        XDP_OP_1048_150_1576_U376/XI17/MN0:g
        XDP_OP_1048_150_1576_U376/XI17/MP0:g
       ** missing connection **                                  XU4278/MP6:d
       ** missing connection **                                  XU4278/MP5:d
  2    Net X13/712                                               N4609
        XU4200/MN8:d
       ** missing connection **                                  (_smp2v):out1
        XU4200/MP3:s
       ** missing connection **                                  (_nand2v):in2
        XU5249/MP8:g
        XU5249/MN10:g
        XDP_OP_1048_150_1576_U382/XI1/MN0:g
        XDP_OP_1048_150_1576_U382/XI1/MP0:g
       ** missing connection **                                  XU4200/MP6:d
       ** missing connection **                                  XU4200/MP5:d
  3    Net X14/1126                                              N3401
       (_sdw2v):in2                                              ** missing connection **
         X14/M531(322.840,303.985):g
       (_smp2v):in1                                              ** missing connection **
         X14/M2758(322.840,305.415):g
       ** missing connection **                                  (SPDW_2_1):input
        XU3192/MN7:g
        XU5146/MN9:g
       ** missing connection **                                  (_smp2v):in1
        XU5146/MP7:g
       ** missing connection **                                  (_smp2v):in2
        XU3192/MP5:g
       ** missing connection **                                  (_invv):out
        XU3939/XI0/MN0:d
        XU3939/XI0/MP0:d
       ** missing connection **                                  (_sdw2v):in2
        Xmdacpn_reg_0__1_0/XI6/MN1:g
        Xmdacpn_reg_0__1_0/XI6/MP1:g
  4    Net X14/1338                                              mdacpn[0]
       (_invv):out                                               ** missing connection **
         X14/X3917/M0(325.150,304.120):s
         X14/X3917/M7(325.150,305.040):s
       (_xra2v):in1                                              ** missing connection **
         X14/X4397/M4(318.910,309.590):g
         X14/M2934(318.680,307.660):g
         X14/X4397/M2(319.950,309.590):g
         X14/M2931(320.275,307.780):g
        XU5105/XI0/MN0:g
        XU5105/XI0/MP0:g
        Xmdacpn_reg_0__1_0/XI5/MN0:d
        Xmdacpn_reg_0__1_0/XI5/MP0:d
       ** missing connection **                                  XU5105/XI2/MN0:g
       ** missing connection **                                  XU5105/XI4/MP0:g
  5    Net X16/969                                               N3433
       (_sdw2v):in1                                              ** missing connection **
         X16/M369(324.070,222.805):g
       (_smp2v):in2                                              ** missing connection **
         X16/M1585(324.070,224.235):g
       ** missing connection **                                  (_nand2v):in1
        XU5124/MP1:g
        XU5124/MN0:g
       ** missing connection **                                  (_nand2v):out
        XU5187/MP0:d
        XU5187/MP1:d
        XU5187/MN1:s
        XU4004/XI0/MN0:g
        XU4004/XI0/MP0:g
        Xmdacpp_reg_0__1_0/XI6/MN1:g
        Xmdacpp_reg_0__1_0/XI6/MP1:g
  6    Net X16/999                                               mdacpp[0]
         X16/X2093/M0(326.380,222.940):s
         X16/X2093/M7(326.380,223.860):s
         X16/X2491/M4(325.470,230.110):g
         X16/M1700(325.240,231.620):g
         X16/X2491/M2(326.510,230.110):g
         X16/M1697(326.835,231.620):g
        Xmdacpp_reg_0__1_0/XI5/MN0:d
        Xmdacpp_reg_0__1_0/XI5/MP0:d
        XU5234/XI0/MN0:g
        XU5234/XI0/MP0:g
       ** missing connection **                                  XU5234/XI2/MN0:g
       ** missing connection **                                  XU5234/XI4/MP0:g
  7    Net X18/928                                               N4610
       (_pup2v):out1                                             ** missing connection **
         X18/X3991/M6(212.680,138.720):s
         X18/X3991/M7(212.210,138.720):d
       ** missing connection **                                  (SPDW_2_1):output
        XU3731/MN5:d
        XU3731/MP5:s
       ** missing connection **                                  (_nand3v):in1
        XU4326/MP2:g
        XU4326/MN0:g
       ** missing connection **                                  XU3731/MP4:d
       ** missing connection **                                  XU4212/MP6:d
       ** missing connection **                                  XU4212/MP5:d
  8    Net X19/781                                               n4629
         X19/X3579/M6(196.280,91.020):s
         X19/X3579/M7(195.810,91.020):d
       ** missing connection **                                  (SPDW_2_1_1):input
        XU3069/MN7:g
       ** missing connection **                                  (OAI_3_1):output
        XU5384/MN8:d
        XU5384/MP5:d
        XU5384/MP6:d
       ** missing connection **                                  (_pup2v):in2
        XU3069/MP6:g
       ** missing connection **                                  XU4254/MP6:d
       ** missing connection **                                  XU4254/MP5:d
  9    Net 503                                                   N1108
           X13/631
10    Net 1127                                                  n3369
           X14/721
11    Net 1345                                                  N3374
           X14/1266
12    Net 554                                                   n3373
           X14/1172
13    Net X18/1186                                              N3342
           X14/1169
14    Net 456                                                   n3337
           X14/688
15    Net 343                                                   N4613
           765
16    Net X14/1124                                              n3372
           X14/1005
17    Net X17/1267                                              N3340
           X14/1237
18    Net X17/1265                                              N3341
           X14/968
19    Net 330                                                   n3403
           1346
20    Net 1248                                                  n3404
           928
21    Net 1439                                                  n3405
           1352
22    Net X17/1262                                              n3406
           X15/870
23    Net 333                                                   N3371
           X14/1008
24    Net 1453                                                  N3339
           X14/1321
25    Net X20/482                                               N4475
           X14/726
26    Net 452                                                   N3338
           X14/1271
27    Net 950                                                   N3435
           X14/1325
28    Net 569                                                   n4621
           X17/1036
29    Net 1124                                                  N3402
           414
30    Net X20/365                                               N4604
           1451
31    Net X18/956                                               N5058
           X17/988
32    Net 1101                                                  n3409
           1028
33    Net X13/764                                               n3410
           891
34    Net X13/762                                               n3411
           X12/149
35    Net X13/763                                               n3412
           1029
36    Net X20/476                                               N4483
           X14/874
37    Net 1544                                                  n3438
           X14/974
38    Net X20/473                                               N4482
           1228
39    Net X20/475                                               N4480
           1349
40    Net X20/474                                               N4479
           548
41    Net X20/472                                               N4481
           538
42    Net X16/728                                               N4603
           X20/368
43    Net X14/906                                               n4491
           X17/1307
44    Net X16/850                                               n4619
           X17/1309
45    Net X17/1264                                              n3437
           1219
46    Net X17/1268                                              n3436
           X14/687
47    Net 1065                                                  N5051
           X13/661
48    Net X14/1125                                              n3370
           X14/691
49    Net 305                                                   n3408
           1033
50    Net X13/742                                               N4614
           764
                                 INCORRECT INSTANCES
51    (_xra2v)                                                  ** missing injected instance **
       Devices:
         X14/M2931(320.275,307.780)  MP(P12)
         X14/M2932(319.705,307.780)  MP(P12)
         X14/X4397/M2(319.950,309.590)  MN(N12)
         X14/X4397/M1(320.470,309.590)  MN(N12)
         X14/M2934(318.680,307.660)  MP(P12)
         X14/X4397/M4(318.910,309.590)  MN(N12)
         X14/M2930(320.980,307.660)  MP(P12)
         X14/X4397/M0(320.990,309.590)  MN(N12)
52    (_xra2v)                                                  ** missing injected instance **
       Devices:
         X16/M1697(326.835,231.620)  MP(P12)
         X16/M1698(326.265,231.620)  MP(P12)
         X16/X2491/M2(326.510,230.110)  MN(N12)
         X16/X2491/M1(327.030,230.110)  MN(N12)
         X16/M1700(325.240,231.620)  MP(P12)
         X16/X2491/M4(325.470,230.110)  MN(N12)
         X16/M1696(327.540,231.620)  MP(P12)
         X16/X2491/M0(327.550,230.110)  MN(N12)
53    (_pup2v)                                                  ** missing injected instance **
       Devices:
         X18/X3991/M7(212.210,138.720)  MP(P12)
         X18/X3991/M6(212.680,138.720)  MP(P12)
54    (_pup2v)                                                  ** missing injected instance **
       Devices:
         X18/X3993/M7(213.850,142.680)  MP(P12)
         X18/X3993/M6(214.320,142.680)  MP(P12)
55    (_pup2v)                                                  ** missing injected instance **
       Devices:
         X19/X3581/M7(211.870,94.440)  MP(P12)
         X19/X3581/M6(211.400,94.440)  MP(P12)
56    (_pup2v)                                                  ** missing injected instance **
       Devices:
         X19/X3579/M7(195.810,91.020)  MP(P12)
         X19/X3579/M6(196.280,91.020)  MP(P12)
57    (_invx3v)                                                 ** missing injected instance **
       Devices:
         X20/M2175(270.005,42.500)  MP(P12)
         X20/X2780/M3(270.005,43.600)  MN(N12)
         X20/X2946/M1(265.485,46.890)  MP(P12)
         X20/X2946/M0(265.535,45.940)  MN(N12)
         X20/X2781/M4(269.890,54.145)  MP(P12)
         X20/M1154(269.890,53.130)  MN(N12)
58    ** missing instance **                                    XU4200/MP5  MP(P12)
59    ** missing instance **                                    XU4200/MP6  MP(P12)
60    ** missing instance **                                    XU4212/MP5  MP(P12)
61    ** missing instance **                                    XU4212/MP6  MP(P12)
62    ** missing instance **                                    XU4278/MP5  MP(P12)
63    ** missing instance **                                    XU4278/MP6  MP(P12)
64    ** missing instance **                                    XU4254/MP5  MP(P12)
65    ** missing instance **                                    XU4254/MP6  MP(P12)
66    ** missing instance **                                    XU5234/XI4/MN0  MN(N12)
67    ** missing instance **                                    XU5234/XI4/MP0  MP(P12)
68    ** missing instance **                                    XU5234/XI2/MN0  MN(N12)
69    ** missing instance **                                    XU5234/XI2/MP0  MP(P12)
70    ** missing instance **                                    XU5105/XI4/MN0  MN(N12)
71    ** missing instance **                                    XU5105/XI4/MP0  MP(P12)
72    ** missing instance **                                    XU5105/XI2/MN0  MN(N12)
73    ** missing instance **                                    XU5105/XI2/MP0  MP(P12)
74    ** missing injected instance **                           (_invv)
        Devices:
        XU5234/XI6/MP0  MP(P12)
        XU5234/XI6/MN0  MN(N12)
75    ** missing injected instance **                           (_invv)
        Devices:
        XU5105/XI6/MP0  MP(P12)
        XU5105/XI6/MN0  MN(N12)
76    ** missing injected instance **                           (_invv)
        Devices:
        XU5234/XI0/MP0  MP(P12)
        XU5234/XI0/MN0  MN(N12)
77    ** missing injected instance **                           (_invv)
        Devices:
        XU5105/XI0/MP0  MP(P12)
        XU5105/XI0/MN0  MN(N12)
78    ** missing injected instance **                           (_invv)
        Devices:
        XU4348/XI8/MP0  MP(P12)
        XU4348/XI8/MN0  MN(N12)
79    ** missing injected instance **                           (_invx2v)
        Devices:
        XU2974/XI0/MP0  MP(P12)
        XU2974/XI0/MN0  MN(N12)
        Xintadd_3_U8/XI1/MP0  MP(P12)
        Xintadd_3_U8/XI1/MN0  MN(N12)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:             101        101            0            0
   Nets:            15566      15436           10            6
   Instances:        2290       2290            0            4    MN(N12)
                     2492       2492            0           12    MP(P12)
                       11         11            0            0    AOI_3_1
                       29         29            0            0    OAI_3_1
                        1          1            0            0    OAI_3_3
                       33         33            0            0    SDW3
                      394        394            0            0    SPDW_2_1
                      271        271            0            0    SPDW_2_1_1
                       98         98            0            0    SPDW_2_2
                       12         12            0            0    SPDW_2_2_1
                       56         56            0            0    SPDW_2_2_2
                      204        204            0            0    SPUP_2_1
                       28         28            0            0    SPUP_2_1_1
                      652        652            0            0    SPUP_2_2
                        4          4            0            0    SPUP_2_2_2
                       33         33            0            0    SPUP_3_2
                      207        207            0            0    SMN2
                        5          5            0            0    SMP2
                      419        419            0            0    _bitcoreb
                     7518       7518            0            5    _invv
                      319        319            0            1    _invx2v
                       24         24            1            0    _invx3v
                        3          3            0            0    _invx4v
                       11         11            0            0    _mx2v
                     1225       1225            0            0    _nand2v
                       66         66            0            0    _nand3v
                       21         21            0            0    _nand4v
                      406        406            0            0    _nor2v
                       30         30            0            0    _nor3v
                       15         15            0            0    _nor4v
                       28         28            0            0    _pdw2v
                      267        267            4            0    _pup2v
                     4346       4346            0            0    _sdw2v
                     4020       4020            0            0    _smp2v
                      842        842            0            0    _tgmb
                       54         54            0            0    _xr2v
                       81         81            2            0    _xra2v
   Total Inst:      26515      26515            7           22
o Statistics:
   47 layout instances were filtered and their pins removed from adjoining nets.
   3620 layout mos transistors were reduced to 525.  96 connecting nets were deleted.
     2927 mos transistors were deleted by parallel reduction.
     168 mos transistors and 96 connecting nets were deleted by split-gate reduction.
   1 net was matched arbitrarily.
o Initial Correspondence Points:
   Ports:        VDD GND D[1] VCDACN[2] VCDACN[0] VCDACN[3] VCDACN[4] VCDACN[5] VMDACN[6] CLK
                 VMDACP[8] VMDACP[6] VCDACP[0] VCDACP[1] VCDACP[3] D[3] VRDACNB[2] VRDACNB[3]
                 VRDACNB[4] VRDACPB[3] VRDACPB[2] VRDACPB[4] VPDACN[0] VPDACN[1] VPDACN[2]
                 VPDACN[3] VPDACN[4] VPDACN[7] VPDACN[6] VPDACN[5] VCM VCDACN[1] VCDACN[6]
                 VMDACN[0] VMDACN[1] VMDACN[2] VMDACN[3] VMDACN[4] VMDACN[5] VMDACN[7] VMDACN[8]
                 VMDACN[9] VMDACN[10] VMDACN[11] VMDACN[12] VMDACN[13] VRDACN[0] VRDACN[1]
                 VRDACN[2] VRDACN[3]
o Ambiguity Resolution Points:
      (Each one of the following objects belongs to a group of indistinguishable objects.
       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
       Layout                                                    Source
                                     Nets
       X14/764                                                   Xmdacpp_reg_0__1_0/QN
                             DETAILED INSTANCE CONNECTIONS
          (This section contains detailed information about connections of
           matched instances that are involved in net discrepancies).
       X13/X3813/M2(357.830,359.910)  MP(P12)                    XU3731/MP4  MP(P12)
         g: 1042                                                   g: n2841
         d: VDD                                                    s: VDD
         b: VDD                                                    b: VDD
         s: X13/713                                                ** no similar net **
         ** X18/928 **                                             d: N4610
       (_invv)                                                   (_invv)
         out: X18/2453                                             out: XDP_OP_1048_150_1576_U382/NET117
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in: X18/929                                               ** no similar net **
         ** X13/712 **                                             in: N4609
       Devices:
         X18/X3842/M4(233.400,142.705)  MP(P12)                    XDP_OP_1048_150_1576_U382/XI1/MP0  MP(P12)
         X18/M1035(233.400,141.690)  MN(N12)                       XDP_OP_1048_150_1576_U382/XI1/MN0  MN(N12)
       (_invv)                                                   (_invv)
         out: X19/2065                                             out: XDP_OP_1048_150_1576_U376/NET119
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in: X19/783                                               ** no similar net **
         ** 1567 **                                                in: n4631
       Devices:
         X19/X3427/M8(235.280,90.950)  MP(P12)                     XDP_OP_1048_150_1576_U376/XI17/MP0  MP(P12)
         X19/M1124(235.280,90.030)  MN(N12)                        XDP_OP_1048_150_1576_U376/XI17/MN0  MN(N12)
       (_smp2v)                                                  (_smp2v)
         in1: X16/1369                                             in2: Xmdacpn_reg_0__1_0/NET62
         out1: X16/1370                                            out1: Xmdacpn_reg_0__1_0/NET52
         out2: VDD                                                 out2: VDD
         in2: X16/969                                              ** N3433 **
         ** X14/1126 **                                            in1: N3401
       Devices:
         X16/M1585(324.070,224.235)  MP(P12)                       Xmdacpn_reg_0__1_0/XI6/MP1  MP(P12)
         X16/M1586(324.390,224.235)  MP(P12)                       Xmdacpn_reg_0__1_0/XI6/MP0  MP(P12)
       (_sdw2v)                                                  (_sdw2v)
         in2: 449                                                  in1: n4
         out2: GND                                                 out2: GND
         in1: X16/969                                              ** N3433 **
         ** X14/1126 **                                            in2: N3401
       Devices:
         X16/M370(324.390,222.805)  MN(N12)                        Xmdacpn_reg_0__1_0/XI6/MN0  MN(N12)
         X16/M369(324.070,222.805)  MN(N12)                        Xmdacpn_reg_0__1_0/XI6/MN1  MN(N12)
       (_smp2v)                                                  (_smp2v)
         in2: X14/1897                                             in2: Xmdacpp_reg_0__1_0/NET62
         out1: X14/1898                                            out1: Xmdacpp_reg_0__1_0/NET52
         out2: VDD                                                 out2: VDD
         in1: X14/1126                                             ** N3401 **
         ** X16/969 **                                             in1: N3433
       Devices:
         X14/M2758(322.840,305.415)  MP(P12)                       Xmdacpp_reg_0__1_0/XI6/MP1  MP(P12)
         X14/M2759(323.160,305.415)  MP(P12)                       Xmdacpp_reg_0__1_0/XI6/MP0  MP(P12)
       (_sdw2v)                                                  (_sdw2v)
         in1: 449                                                  in1: n4
         out2: GND                                                 out2: GND
         in2: X14/1126                                             ** N3401 **
         ** X16/969 **                                             in2: N3433
       Devices:
         X14/M532(323.160,303.985)  MN(N12)                        Xmdacpp_reg_0__1_0/XI6/MN0  MN(N12)
         X14/M531(322.840,303.985)  MN(N12)                        Xmdacpp_reg_0__1_0/XI6/MN1  MN(N12)
       (_invv)                                                   (_invv)
         in: 509                                                   in: mdacnn[35]
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         out: 1218                                                 ** no similar net **
         ** X14/1126 **                                            out: N3401
       Devices:
         X15/X2406/M1(203.695,264.030)  MP(P12)                    XU3939/XI0/MP0  MP(P12)
         X15/X2406/M0(203.645,264.980)  MN(N12)                    XU3939/XI0/MN0  MN(N12)
       (_invv)                                                   (_invv)
         out: X14/970                                              out: n3353
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in: X14/1184                                              ** no similar net **
         ** X16/969 **                                             in: N3433
       Devices:
         X14/X4286/M1(211.775,275.670)  MP(P12)                    XU4004/XI0/MP0  MP(P12)
         X14/X4286/M0(211.825,274.720)  MN(N12)                    XU4004/XI0/MN0  MN(N12)
       (_invv)                                                   (_invv)
         in: X16/1372                                              in: Xmdacpn_reg_0__1_0/NET53
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         out: X16/999                                              ** mdacpp[0] **
         ** X14/1338 **                                            out: mdacpn[0]
       Devices:
         X16/X2093/M7(326.380,223.860)  MP(P12)                    Xmdacpn_reg_0__1_0/XI5/MP0  MP(P12)
         X16/X2093/M0(326.380,222.940)  MN(N12)                    Xmdacpn_reg_0__1_0/XI5/MN0  MN(N12)
       (_invv)                                                   (_invv)
         in: X14/1900                                              in: Xmdacpp_reg_0__1_0/NET53
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         out: X14/1338                                             ** mdacpn[0] **
         ** X16/999 **                                             out: mdacpp[0]
       Devices:
         X14/X3917/M7(325.150,305.040)  MP(P12)                    Xmdacpp_reg_0__1_0/XI5/MP0  MP(P12)
         X14/X3917/M0(325.150,304.120)  MN(N12)                    Xmdacpp_reg_0__1_0/XI5/MN0  MN(N12)
       (_nand2v)                                                 (_nand2v)
         in1: 1221                                                 in1: n5374
         in2: X14/1222                                             in2: n5375
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         out: X14/1184                                             ** no similar net **
         ** X16/969 **                                             out: N3433
       Devices:
         X14/M1974(209.790,272.180)  MN(N12)                       XU5187/MN0  MN(N12)
         X14/M1975(209.475,272.785)  MN(N12)                       XU5187/MN1  MN(N12)
         X14/M3181(209.845,271.300)  MP(P12)                       XU5187/MP1  MP(P12)
         X14/M3182(209.510,270.785)  MP(P12)                       XU5187/MP0  MP(P12)
       (_nand2v)                                                 (_nand2v)
         in1: 536                                                  in2: n122
         out: X14/687                                              out: n3436
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in2: X14/1184                                             ** no similar net **
       Devices:
         X14/M116(211.020,272.180)  MN(N12)                        XU5124/MN0  MN(N12)
         X14/M117(210.705,272.785)  MN(N12)                        XU5124/MN1  MN(N12)
         X14/M2451(211.075,271.300)  MP(P12)                       XU5124/MP1  MP(P12)
         X14/M2452(210.740,270.785)  MP(P12)                       XU5124/MP0  MP(P12)
       (_nand2v)                                                 (_nand2v)
         in2: 787                                                  in1: n54
         out: X18/2191                                             out: XU5249/NET35
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in1: X18/929                                              ** no similar net **
         ** X13/712 **                                             in2: N4609
       Devices:
         X18/X3798/M0(244.380,139.640)  MN(N12)                    XU5249/MN11  MN(N12)
         X18/X3798/M1(244.700,139.640)  MN(N12)                    XU5249/MN10  MN(N12)
         X18/X3798/M2(244.380,138.720)  MP(P12)                    XU5249/MP9  MP(P12)
         X18/X3798/M3(244.900,138.720)  MP(P12)                    XU5249/MP8  MP(P12)
       (_smp2v)                                                  (_smp2v)
         in1: 376                                                  in1: n116
         out1: X15/834                                             out1: n1936
         out2: VDD                                                 out2: VDD
         in2: 1218                                                 ** no similar net **
       Devices:
         X15/X2365/M0(157.960,263.970)  MP(P12)                    XU3192/MP3  MP(P12)
         X15/X2365/M1(158.430,263.970)  MP(P12)                    XU3192/MP5  MP(P12)
       (_smp2v)                                                  (_smp2v)
         in2: 447                                                  in2: n159
         out1: X14/794                                             out1: n4407
         out2: VDD                                                 out2: VDD
         in1: 1218                                                 ** no similar net **
       Devices:
         X14/X3955/M5(224.620,285.830)  MP(P12)                    XU5146/MP7  MP(P12)
         X14/X3955/M4(224.940,285.830)  MP(P12)                    XU5146/MP4  MP(P12)
       (_smp2v)                                                  (_smp2v)
         in1: 1041                                                 in1: n2925
         in2: X13/712                                              in2: N4609
         out2: VDD                                                 out2: VDD
         out1: X13/713                                             ** no similar net **
         ** X18/928 **                                             out1: N4610
       Devices:
         X13/X3813/M0(356.810,359.910)  MP(P12)                    XU3731/MP3  MP(P12)
         X13/X3813/M1(357.280,359.910)  MP(P12)                    XU3731/MP5  MP(P12)
       (_nand3v)                                                 (_nand3v)
         in1: X13/X3663/7                                          in3: XU4326/NET20
         in2: 343                                                  in2: N4613
         out: 1043                                                 out: n2109
         sup1: VDD                                                 sup1: VDD
         sup2: GND                                                 sup2: GND
         in3: X13/713                                              ** no similar net **
         ** X18/928 **                                             in1: N4610
       Devices:
         X13/X3663/M3(364.320,361.040)  MN(N12)                    XU4326/MN0  MN(N12)
         X13/X3663/M2(364.760,361.040)  MN(N12)                    XU4326/MN3  MN(N12)
         X13/X3663/M1(365.230,361.040)  MN(N12)                    XU4326/MN4  MN(N12)
         X13/X3663/M7(364.300,360.120)  MP(P12)                    XU4326/MP2  MP(P12)
         X13/X3663/M6(364.760,360.120)  MP(P12)                    XU4326/MP1  MP(P12)
         X13/X3663/M5(365.280,360.120)  MP(P12)                    XU4326/MP0  MP(P12)
       (_smp2v)                                                  (_smp2v)
         in1: 208                                                  in1: n120
         in2: X18/1110                                             in2: n3778
         out2: VDD                                                 out2: VDD
         out1: X18/929                                             ** no similar net **
         ** X13/712 **                                             out1: N4609
       Devices:
         X18/X3993/M5(214.860,142.680)  MP(P12)                    XU4200/MP4  MP(P12)
         X18/X3993/M4(215.330,142.680)  MP(P12)                    XU4200/MP3  MP(P12)
       (_smp2v)                                                  (_smp2v)
         in1: X19/854                                              in1: n3613
         in2: 422                                                  in2: n3315
         out2: VDD                                                 out2: VDD
         out1: X19/783                                             ** no similar net **
         ** 1567 **                                                out1: n4631
       Devices:
         X19/X3581/M5(210.860,94.440)  MP(P12)                     XU4278/MP4  MP(P12)
         X19/X3581/M4(210.390,94.440)  MP(P12)                     XU4278/MP3  MP(P12)
       (_pup2v)                                                  (_pup2v)
         in1: 348                                                  in1: n5218
         out1: X18/1385                                            out1: n2097
         out2: VDD                                                 out2: VDD
         in2: X18/752                                              ** no similar net **
         ** X19/781 **                                             in2: n4629
       Devices:
         X18/X4679/X1/M7(331.110,160.860)  MP(P12)                 XU3069/MP5  MP(P12)
         X18/X4679/X1/M6(331.580,160.860)  MP(P12)                 XU3069/MP6  MP(P12)
       (SPDW_2_1)                                                (SPDW_2_1)
         input: 1041                                               input: n2925
         input: X13/712                                            input: N4609
         input: 1042                                               input: n2841
         output: X13/713                                           ** no similar net **
         ** X18/928 **                                             output: N4610
       Transistors:
         X13/M1332(356.840,360.760)  MN(N12)                       XU3731/MN6  MN(N12)
         X13/M1333(357.340,360.760)  MN(N12)                       XU3731/MN7  MN(N12)
         X13/M1334(357.920,360.760)  MN(N12)                       XU3731/MN5  MN(N12)
         output: X14/794                                           output: n4407
         input: 447                                                input: n159
         input: X14/1983                                           input: XU5146/NET35
         input: 1218                                               ** no similar net **
         ** X14/1126 **                                            input: N3401
       Transistors:
         X14/M689(224.970,287.450)  MN(N12)                        XU5146/MN8  MN(N12)
         X14/M690(224.490,287.250)  MN(N12)                        XU5146/MN9  MN(N12)
         X14/M691(223.970,287.250)  MN(N12)                        XU5146/MN7  MN(N12)
         output: X15/834                                           output: n1936
         input: 376                                                input: n116
         input: 108                                                input: n4128
       Transistors:
         X15/M938(157.990,264.820)  MN(N12)                        XU3192/MN6  MN(N12)
         X15/M939(158.490,264.820)  MN(N12)                        XU3192/MN7  MN(N12)
         X15/M940(159.070,264.820)  MN(N12)                        XU3192/MN5  MN(N12)
       (SPDW_2_1_1)                                              (SPDW_2_1_1)
         output: X18/1385                                          output: n2097
         input: 195                                                input: n4809
         input: X18/1029                                           input: n4632
         input: 348                                                input: n5218
         input: X18/752                                            ** no similar net **
         ** X19/781 **                                             input: n4629
       Transistors:
         X18/X4679/X1/M0(332.630,161.870)  MN(N12)                 XU3069/MN6  MN(N12)
         X18/X4679/X1/M1(332.120,161.870)  MN(N12)                 XU3069/MN4  MN(N12)
         X18/X4679/X1/M2(331.555,161.870)  MN(N12)                 XU3069/MN7  MN(N12)
         X18/X4679/X1/M3(331.145,161.870)  MN(N12)                 XU3069/MN8  MN(N12)
       (OAI_3_1)                                                 (OAI_3_1)
         input: X18/746                                            input: bit_counter[2]
         input: 1567                                               input: n4631
         input: X18/785                                            input: n4654
         input: 1569                                               input: bit_counter[3]
         output: X18/752                                           ** no similar net **
         ** X19/781 **                                             output: n4629
       Transistors:
         X18/M73(333.400,156.290)  MN(N12)                         XU5384/MN7  MN(N12)
         X18/M74(333.880,156.290)  MN(N12)                         XU5384/MN6  MN(N12)
         X18/M75(334.400,156.290)  MN(N12)                         XU5384/MN5  MN(N12)
         X18/M76(334.860,156.290)  MN(N12)                         XU5384/MN8  MN(N12)
         X18/X3683/M0(333.440,157.440)  MP(P12)                    XU5384/MP2  MP(P12)
         X18/X3683/M1(333.920,157.440)  MP(P12)                    XU5384/MP4  MP(P12)
         X18/X3683/M2(334.240,157.440)  MP(P12)                    XU5384/MP5  MP(P12)
         X18/X3683/M3(334.860,158.010)  MP(P12)                    XU5384/MP6  MP(P12)
         input: X18/1110                                           input: n3778
         input: 208                                                input: n120
         input: X18/1084                                           input: n3657
         input: X18/1079                                           input: n3656
         output: X18/929                                           ** no similar net **
         ** X13/712 **                                             output: N4609
       Transistors:
         X18/X3993/M0(215.370,141.670)  MN(N12)                    XU4200/MN6  MN(N12)
         X18/X3993/M1(214.860,141.670)  MN(N12)                    XU4200/MN4  MN(N12)
         X18/X3993/M2(214.295,141.670)  MN(N12)                    XU4200/MN7  MN(N12)
         X18/X3993/M3(213.885,141.670)  MN(N12)                    XU4200/MN8  MN(N12)
         input: 422                                                input: n3315
         input: X19/854                                            input: n3613
         input: X19/1065                                           input: n3612
         input: X19/916                                            input: n3611
         output: X19/783                                           ** no similar net **
         ** 1567 **                                                output: n4631
       Transistors:
         X19/X3581/M0(210.350,95.450)  MN(N12)                     XU4278/MN6  MN(N12)
         X19/X3581/M1(210.860,95.450)  MN(N12)                     XU4278/MN4  MN(N12)
         X19/X3581/M2(211.425,95.450)  MN(N12)                     XU4278/MN7  MN(N12)
         X19/X3581/M3(211.835,95.450)  MN(N12)                     XU4278/MN8  MN(N12)
                                         SUMMARY
Total CPU Time:      4 sec
Total Elapsed Time:  4 sec
GMT+8, 2025-12-20 04:49 , Processed in 0.034068 second(s), 4 queries , Gzip On, Redis On.
