查看: 17927|回复: 32
[资料] Cadence 最新套件下载
发表于 2015-4-4 22:28:49 | 显示全部楼层 |阅读模式
1.Base_IC06.16.005
2.Hotfix_IC06.16.110
3.MMSIM141
4.Hotfix_MMSIM14.10.400
3.Update_ASSURA04.14.001-616
网盘地址:http://pan.baidu.com/s/1jGFxpjw
发表于 2015-4-5 10:01:47 | 显示全部楼层
回复 1# 雪狐地带
非常感谢,顶起,不知是否crack版本?
发表于 2015-4-5 11:06:12 | 显示全部楼层
thanks.
very good
发表于 2015-4-5 15:23:34 | 显示全部楼层
裂缝是在论坛上提供。
发表于 2015-4-6 06:57:17 | 显示全部楼层
是linux还是win
发表于 2015-4-6 07:01:10 | 显示全部楼层
怎么破解啊
 楼主| 发表于 2015-4-6 21:08:55 | 显示全部楼层
回复 5# alienwarexie
   是linux,cadence ic 只有linux版的把
 楼主| 发表于 2015-4-6 21:11:36 | 显示全部楼层
回复 2# kaikanertan
   不是crack版本的,patch在咱论坛上有
发表于 2015-4-6 21:26:09 | 显示全部楼层
请问楼主安装了Hotfix_IC06.16.110并在使用之中吗?若不是,请不要再上传误导其他人下载安装这个启动即crash崩溃而不能用的最新Hotfix。我在上周已经在EDA资源使用坛上说过了,Cadence最近两个IC的Hotfix(分别是ISR10和ISR11)经过目前的patch加工后不能正常启动使用。可以推测Cadence已经对IC616进行过某些更改,使得我们目前使用的patch无法成功应用了。还有,这个ISR11(即Hotfix_IC06.16.110)的README上新增加了一段以前没有的用户使用条款如下:
# Terms and Conditions of Use
Please read these Terms carefully prior to downloading or using the products. You must protect
the product(s) from unauthorized reproduction, publication, use or distribution. If any product
or portion thereof is copied to or used on a computer connected to a network, you must ensure
that the product may not be used or copied by unlicensed persons.
To help ensure that only authorized copies of Cadence software are being used, Cadence is implementing
monitoring technologies that will obtain and transmit to Cadence non-proprietary data in the event
a Cadence software product is tampered with.
  No data will be collected or transmitted unless unauthorized
modifications to Cadence software product(s) are made or an unauthorized hosting of the Cadence license
server or software is detected.
By downloading the product(s), you confirm that you have the authority to act on behalf of your employer.
By downloading or using the product(s) you hereby agree to the use of such technology and transmission
of such non-proprietary data by Cadence.
我已经将其中的重点加粗。即Cadence为防盗版正在IC软件中实施监控技术,将可以监测到IC软件被patch更改并将获得的篡改过的非法数据传送回Cadence。
发表于 2015-4-6 22:31:29 | 显示全部楼层
哇塞~~616都出来啦~
GMT+8, 2025-12-20 17:44 , Processed in 0.018108 second(s), 3 queries , Gzip On, Redis On.
