查看: 32434|回复: 144
[资料] [2015Book]A Digital Phase Locked Loop based Signal and Symbol Recovery
发表于 2015-3-17 01:27:08 | 显示全部楼层 |阅读模式
A Digital Phase Locked Loop based Signal and Symbol Recovery System for Wireless Channel[2015 Springer]
Basab Bijoy Purkayastha, Kandarpa Kumar Sarma
The book reports two approaches of implementation of the essential components of a Digital Phase Locked Loop based system for dealing with wireless channels showing Nakagami-m fading. It is mostly observed in mobile communication. In the first approach, the structure of a Digital phase locked loop (DPLL) based on Zero Crossing (ZC) algorithm is proposed. In a modified form, the structure of a DPLL based systems for dealing with Nakagami-m fading based on Least Square Polynomial Fitting Filter is proposed, which operates at moderate sampling frequencies. A sixth order Least Square Polynomial Fitting (LSPF) block and Roots Approximator (RA) for better phase-frequency detection has been implemented as a replacement of Phase Frequency Detector (PFD) and Loop Filter (LF) of a traditional DPLL, which has helped to attain optimum performance of DPLL. The results of simulation of the proposed DPLL with Nakagami-m fading and QPSK modulation is discussed in detail which shows that the proposed method provides better performance than existing systems of similar type.
Content:
Front Matter....Pages i-xxi
Introduction....Pages 1-29
Transmitter Receiver Techniques....Pages 31-47
Modulation Techniques and Signal Processing....Pages 49-87
Basic Considerations of PLL and Its Types....Pages 89-101
Digital Phase-Locked Loop....Pages 103-126
Synchronization....Pages 127-151
A Zero-Crossing Algorithm-Based Digital Phase-Locked Loop....Pages 153-162
Least Square Polynomial Fitting-Based Digital Phase-Locked Loop....Pages 163-172
A DPLL-Based Recovery System for Nakagami-m Fading Channel....Pages 173-185
Coding Assisted Carrier and Symbol Recovery Using DPLL....Pages 187-195
Carrier Phase Detection of Rayleigh and Rician Faded Signals Using Digital Phase-Locked Loop....Pages 197-217
DPLL-Based Square Loop for Carrier Synchronization Over Fading Channel....Pages 219-231
Conclusions and Future Direction....Pages 233-242
Back Matter....Pages 243-244
A Digital Phase Locked Loop based Signal and Symbol Recovery System for Wireless Channel.pdf (10.43 MB , 下载次数: 1926 )
发表于 2015-3-17 09:10:39 | 显示全部楼层
A Digital Phase Locked Loop based Signal and Symbol Recovery !!!
发表于 2015-3-17 09:24:10 | 显示全部楼层
good reference
感謝大大的分享
发表于 2015-3-17 09:41:08 | 显示全部楼层
thx for sharing~
发表于 2015-3-17 17:00:40 | 显示全部楼层
是Springer2015年的书,谢谢
发表于 2015-3-17 17:06:35 | 显示全部楼层
2015symbol
发表于 2015-3-17 18:28:50 | 显示全部楼层
好书要收藏
发表于 2015-3-17 20:41:00 | 显示全部楼层
感谢 感谢
发表于 2015-3-17 21:07:12 | 显示全部楼层
学习学习
发表于 2015-3-17 23:57:25 | 显示全部楼层
GMT+8, 2025-12-26 18:14 , Processed in 0.027680 second(s), 8 queries , Gzip On, Redis On.
