查看: 7046|回复: 8
[求助] 使用UPF做DC综合,module里部分reg没有被例化成标准单元库里的器件,而是gtech状态
发表于 2015-2-15 16:58:33 | 显示全部楼层 |阅读模式
小女子第一次做带UPF的综合,麻烦大侠们帮我解答这个问题。
Warning代码为:
OPT-301
PWR-662
log如下:
  Processing 'pso_rstn_gen'
  Processing 'retreg_array'
Warning: design 'retreg_array' has 128 out of 259 cells marked size-only which may limit optimization. (OPT-301)
Warning: Register 'text_retn3_reg_31_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_30_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_29_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_28_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_27_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_26_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_25_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_24_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
Warning: Register 'text_retn3_reg_23_' (**FFGEN**) will not be translated to the retention specification. (PWR-662)
UPF 关于retetion部分如下
set_retention PD_PSO_ret \
-domain PD_PSO \
-retention_power_net VDD \
-retention_ground_net VSS \
-elements {u_aes_core_top/aes_core_main/aes_algo_pso_dign/aes_algo_pso/u_ret}
set_retention_control PD_PSO_ret \
-domain PD_PSO \
-save_signal {u_aes_core_top/retain_n_o low} \
-restore_signal {u_aes_core_top/retain_n_o high}
map_retention_cell PD_PSO_ret \
-domain PD_PSO \
-lib_cell_type DRFF
使用man OPT-301 检查约束,无size_only设置,没发现可疑之处。
man PWR-662, compile_ultra使用应该没有问题。
在pmk的标准单元库里可以找到DRFF对应的器件,但不能确定库一定是正确的。
求助求助求助,是哪里出了问题?怎样才能正确综合这个模块?
发表于 2015-2-16 14:47:55 | 显示全部楼层
pmk lib做的如何,可以打开看下这个cell, 该有的属性有没有,
可以找个别的pmk来试试,
 楼主| 发表于 2015-2-16 15:24:54 | 显示全部楼层
回复 2# icfbicfb
   换了个pmk库,还是报Warning,查看lib,常见的 retention cell :DRFF,pg_pin,primary power,primary ground ,bacup power,backup ground属性都有。
 楼主| 发表于 2015-3-13 10:38:42 | 显示全部楼层
问题解决了,是PMK库的问题,PMK库里对Retetion Register 的save,restore的定义定义反了,改掉以后,RR就能正常被综合被插入了。
发表于 2015-3-13 11:29:54 | 显示全部楼层
看来还是库的问题,
发表于 2015-3-13 13:48:49 | 显示全部楼层
学习了,
发表于 2015-4-16 10:07:53 | 显示全部楼层
库中怎么会save和restore定义反的呢?怎么发现的
 楼主| 发表于 2015-4-23 16:19:45 | 显示全部楼层
回复 7# yangwu3101
   不知道为什么会反,和其他工艺的库文件对比,对比的那个库的save和restore和用的这个库的定义是相反的。
发表于 2016-1-31 15:28:54 | 显示全部楼层
请问pmk库在SMIC工艺库的哪个文件夹下?
GMT+8, 2025-12-19 12:40 , Processed in 0.024857 second(s), 5 queries , Gzip On, Redis On.
