查看: 1798|回复: 0
[招聘] 【Marvell全职】ASIC Design/Implementation/DFT Engineer
发表于 2015-2-13 16:30:47 | 显示全部楼层 |阅读模式
1Job Title: SoC ASIC Engineer
Department: Cellular Engineering
Job Description: modem:
3G: TD-SCDMA and WCDMA modem development
4G: TD-LTE modem development
SoC: next generation cellphone SoC full design cycle from spec.to massproduction.
Largest chip inside Marvell.
1) R&D L2/L3 of the above protocol stacks.
2)Integration and Testing with the UE system.
Qualification:
MS degree in microelectronics, or electrical engineering.
At least three years working experience.
Experience in real design projects (front-end or backend) is a strongplus.
Good team work spirit and communication skill. Eager to learn, work and grow ina challenging project.
2Job Title: ASIC Implementation Engineer
Job Description:
- Block, IP macro or SoC levelimplementation in 28nm or 20nm TSMC/UMC process
- UPF Synthesis with Synopsys DC orDCT/G flows
- RTL2Gate and Gate2Gate formal checkwith LEC and/or formality tools.
- Working with BE team to timingclosure in Primetime-SI on multi-corners and multi-modes
Ability to build or perfect the EDA-methodology-flow withperl, tcl or shell
- Knowledge on DFT (mbist/scan)will be an added advantage
Qualifications:
- BSEE degree or above
- Strong understandingof synthesis flow using DC/DCT/DCG - for a low power (UPF) and high speed-complex SoC
- Hands on experiencewith formal verification tools such as LEC and/or formality
- Must have the CTSconceptions in ICC at P&R stage
- Strong STA skills. Must have thorough knowledge on closing timing at unit andtop level
- Experience in mbistand scan will be plus
- Proficient in Perl,Tcl and Shell programming
-Good team work spirit
3Job Title: ASIC DFTdesign Engineer
Job Description:
-Block, IP and SoC level DFT implementation (JTAG, Scan,Mbist and analog/IP test etc.) and RTL integration;
-Participate in test spec/plan definition; createthe DFT design document and signoff DFT review checklists;
-Test patterns/vectors generation and verification;
-Interface to backend team on physical design and timingclosure;
-Interface to test engineers on ATE and vectors bring-upand debugging;
-Chip DFT quality sign-off
-DFT STA, constraint generation, formal and timingclosure
Qualifications:
- DFT design and integration experience
- Hands on DFT implementation experience(Bscan, Mbist, DC/AC Scan, analog IP test circuit integration, IDDQ test, ATPGand test pattern verification)
- Expertise with DFT tools from Synopsy,Mentor, Syntest etc.
- Strong logic design and verificationbackground
- Experience in Synthesis and STA willbe plus
- Proficient in Perl, tcl and shellprogramming
- Good team work spirit
If you are interested in the position, please send your resume to the following email address:   jiangrr@marvell.com
Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
GMT+8, 2025-12-27 18:29 , Processed in 0.011875 second(s), 3 queries , Gzip On, Redis On.
