查看: 3034|回复: 4
[原创] 使用Xilinx的FPGA开发板中DCM的问题的解决方法
发表于 2015-2-6 11:49:12 | 显示全部楼层 |阅读模式
[p=193, 2, left]在使用
[p=193, 2, left]Xilinx
[p=193, 2, left]的
[p=193, 2, left]FPGA
[p=193, 2, left]开发板时,在设计时内部需要使用不同的时钟频率,
[p=193, 2, left]可能会需要一个甚至多个
[p=193, 2, left]DCM
[p=193, 2, left]把所需要的时钟频率倍频或者是分频出来,
[p=193, 2, left]在编
[p=193, 2, left]译、综合、映射、布局布线的过程中会出现下列问题(
[p=193, 2, left]ERROR
[p=193, 2, left]):
[p=207, 2, left]ERRORlace:1012 - A clock IOB / DCM component pair have been found that are
[p=207, 2, left]not placed at an optimal clock IOB / DCM
[p=207, 2, left]site
[p=207, 2, left]pair.
[p=207, 2, left]The
[p=207, 2, left]clock
[p=207, 2, left]component
[p=207, 2, left]<u1/u0/DCM_SP_INST>
[p=207, 2, left]is
[p=207, 2, left]placed
[p=207, 2, left]at
[p=207, 2, left]<DCM_X0Y1>.
[p=207, 2, left]The clock IO/DCM site can be
[p=207, 2, left]paired if they are placed/locked in the same quadrant.
[p=207, 2, left]The IO component <clk>
[p=207, 2, left]is placed at site <32>.
[p=207, 2, left]This will
[p=207, 2, left]not allow the use of the fast path between the IO and the Clock buffer. If this sub
[p=207, 2, left]optimal condition is acceptable
[p=207, 2, left]for
[p=207, 2, left]this
[p=207, 2, left]design,
[p=207, 2, left]you
[p=207, 2, left]may
[p=207, 2, left]use
[p=207, 2, left]the
[p=207, 2, left]CLOCK_DEDICATED_ROUTE
[p=207, 2, left]constraint
[p=207, 2, left]in
[p=207, 2, left]the .ucf file to demote this message to a
[p=207, 2, left]WARNING and allow your design to continue. However, the use of this override
[p=207, 2, left]is highly discouraged as it may lead to
[p=207, 2, left]very poor timing results. It is recommended that this error condition be corrected
[p=207, 2, left]in the design. A list of all the
[p=207, 2, left]COMP.PINs used in this clock placement rule is listed below. These examples can
[p=207, 2, left]be used directly in the .ucf file to
[p=207, 2, left]override this clock rule.
[p=207, 2, left]< NET "clk" CLOCK_DEDICATED_ROUTE = FALSE; >
[p=207, 2, left]<
[p=207, 2, left]PIN
[p=207, 2, left]"u1/u0/DCM_SP_INST.CLKIN"
[p=207, 2, left]=
[p=207, 2, left]FALSE; >
[p=193, 2, left]在
[p=193, 2, left]UCF
[p=193, 2, left]里加入上面两句的话,
[p=193, 2, left]clk
[p=193, 2, left]和
[p=193, 2, left]clkin
[p=193, 2, left]走的不是全局时钟线:
[p=207, 2, left]<
[p=207, 2, left]PIN
[p=207, 2, left]=
发表于 2015-2-6 13:59:12 | 显示全部楼层
这个有可能是bufg的问题
你的帖子格式有问题,看起来费劲
发表于 2015-2-6 16:12:34 | 显示全部楼层
DJNHDFJNFXC DRTHJDRSJTSRJDFJ
发表于 2015-2-6 16:14:13 | 显示全部楼层
JNDFJHS DHVSEHRH
发表于 2015-2-7 19:40:25 | 显示全部楼层
回复 1# liping09003
应该是时钟没有经过全局时钟管脚进入fpga,在ucf中约束
GMT+8, 2025-12-19 13:53 , Processed in 0.015158 second(s), 3 queries , Gzip On, Redis On.
