查看: 1441|回复: 0
[招聘] Cadence招聘资深模拟设计工程师
发表于 2015-2-3 11:28:36 | 显示全部楼层 |阅读模式
Cadence招聘资深模拟设计工程师
Title: Principal/LeadAnalog Design Engineer
Location SH
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you haveinterest, PLS send your update CV to zhangyl@cadence.com
Position Description:
Analog IC designer -responsible for the design and development of analog/mixed signal IC circuitblocks from initial concept/specification through final verification ofconformance to IP specifications. Focus area of design will be in DDR IO in lowgeometry CMOS processes.  May alsosupport Cadence SerDes/AFE IP development by owning the design circuit buildingblocks with support from the design team. Background should demonstrate good problem solving skills, excellentanalog aptitude, good communication skills, and ability to work cooperatively ina team environment.
Position Requirements:
1.MSEE - minimum 6 years relevant experience
2.Must have design experience for some basic analog functioncircuit blocks including: drivers, plls, op-amps, comparators, voltage andcurrent references, phase-locked loops. Must be proficient in using CAD toolsfor circuit analog simulation, analysis, and verification in CMOS processes.
GMT+8, 2025-12-28 16:21 , Processed in 0.015351 second(s), 6 queries , Gzip On, Redis On.
