查看: 2929|回复: 3
[讨论] HFSS仿真天线的三维增益图
发表于 2015-1-30 15:48:54 | 显示全部楼层 |阅读模式
这是三维增益图,最大增益在-4.7dB,这个结果合理吗?
发表于 2015-1-30 21:00:29 | 显示全部楼层
合不合理 要看你仿什么啊
 楼主| 发表于 2015-1-31 09:54:37 | 显示全部楼层
回复 2# xuexi2o11
弯折线偶极子天线的变形。。。
发表于 2015-1-31 12:17:08 | 显示全部楼层
I am not familiar with HFSS. You may check your result in this way:
your measurement is GainTotal. I think that you measure the (radiated power/ input power)
If my guess is correct, the gain equation should include antenna gain and antenna return loss.
You may check the antenna input reflection whether it is < -15dB or not.
In most case, the loss is due to input mis-match.
GMT+8, 2025-12-22 04:40 , Processed in 0.020105 second(s), 6 queries , Gzip On, Redis On.
