查看: 2275|回复: 0
[求助] freescale单片机ROM问题
发表于 2015-1-23 11:04:47 | 显示全部楼层 |阅读模式
程序超出ROM_C000,用了ROM_4000,但是,codewarrior中说需要设置:-OnB=b   如图所示: QQ截图20150123110657.png
即:in case you want to use ROM_4000 here as well, make sure
                                 that all files (incl. library files) are compiled with the
                                 option: -OnB=b
请问,这个设置在哪里设置?
GMT+8, 2025-10-8 11:40 , Processed in 0.014991 second(s), 6 queries , Gzip On, Redis On.
