查看: 2646|回复: 0
[求助] 在windows xp下使用批处理命令,报错求助
发表于 2015-1-23 10:40:13 | 显示全部楼层 |阅读模式
写了一个批处理命令,modelsim后台仿真,调用debussy打开波形文件:
@echo off
echo vsim +notimingchecks -pli novas_fli.dll -L simprims_ver -sdfmax /uut=../prj/netgen/par/top_timesim.sdf rx_tb glbl>test.do
echo run 10us>>test.do
echo quit -sim>>test.do
echo quit>>test.do
vlib work
vmap work work
vlib simprims_ver
vmap simprims_ver $XILINX/verilog/mti_se/simprims_ver
vlog -nologo ../prj/netgen/par/top_timesim.v
vlog -nologo rx_tb.v
vlog -nologo glbl.v
vsim -c -do test.do
echo ******************
echo SIMULATION END!!!
rmdir /s/q work
rmdir /s/q simprims_ver
if exist *.wlf del *.wlf
if exist modelsim.ini del modelsim.ini
del test.do
tasklist |find /i "Debussy.exe"
if %errorlevel% NEQ 0 (%Debussy% -nWave -ssf rx_tb.fsdb & )
最后打开debussy的时候,报错:此时不应有),请问怎么修改?我对批处理不太懂,谢谢!
GMT+8, 2025-12-23 14:24 , Processed in 0.017206 second(s), 7 queries , Gzip On, Redis On.
