查看: 3514|回复: 3
[原创] compare CT SC sigma-delta ADC 欢迎大家补充
发表于 2015-1-22 15:13:20 | 显示全部楼层 |阅读模式
CT ∆ΣADCs advantage:
1) high speed and low power requirement
2) inherent anti-aliasing properties without SC noise
3) lower the switch performance without the SC based front-end
4) high input impedance and save the input buffer
5) absence of stringent settling requirements enables CT converters to digitize signals up to several hundred MHz
disadvatages:
1)sensitive to clock jitter 2)the loop coefficient are sensitive to technology parameters
3)modulator is dependent on clock frequency 4)sensitive to feedback loop delay
SC ∆ΣADCs advantage:
1)mature design methodologies and robustness  2)achieve relatively high linearity and high resolution
3) tolerant of clock jitter  4) the filter coefficients are very stable 5)the filter coefficients is independent on clock frequency
发表于 2015-1-25 03:15:56 | 显示全部楼层
goooooooood
发表于 2015-2-2 00:37:59 | 显示全部楼层
回复 1# zy_hit
推荐Sigma Delta ADC/DAC/PLL交流群:  317605756。
本群主要专注Sigma Delta ADC/DAC/PLL 建模/设计/仿真/测试/应用等问题的讨论交流。比如,
1). 系统建模与非理想分析
2). DT-CT转换
3). loop filter 设计
4). excess loop delay 补偿
5). multi-bit DAC线性化
6). audio and measurement ADC
7). 宽带CT-SDM
 楼主| 发表于 2015-2-2 14:32:43 | 显示全部楼层
回复 3# seamasc1
GMT+8, 2025-12-25 13:56 , Processed in 0.016354 second(s), 7 queries , Gzip On, Redis On.
