楼主: cybjut
[求助] cadence spectreRF仿真jitter结果中JCC设置选项中的(K)是什么意思?
发表于 2019-11-22 11:03:30 | 显示全部楼层
谢谢分享
发表于 2019-12-16 14:48:40 | 显示全部楼层
Jee is the edge-to-edge jitter. It is the variation in the delay between a triggering event and a response event. When measuring edge-to-edge jitter, a clean jitter-free input is assumed. Edge-to-edge jitter assumes an input signal, and so is only defined for driven systems. It is an input-referred jitter metric, meaning that the jitter measurement is referenced to a point on a noise-free input signal, so the reference point is fixed. No such signal exists in autonomous systems.
Jc is referred to as k-cycle jitter or long-term jitter. It is a measure of the uncertainty in the length of k cycles and has units of time. When k=1, the standard deviation of the length of a single period, is often referred to as the period jitter, and it denoted J, where J = Jc when k=1.
Jcc is cycle-to-cycle jitter. It is a metric designed to identify large adjacent cycle displacements. It is like edge-to-edge jitter in that it is a scalar jitter metric that does not contain information about the correlation in the jitter between distant transitions. However, it differs in that it is a measure of short-term jitter that is relatively insensitive to long-term jitter.
发表于 2020-3-10 18:17:03 | 显示全部楼层
thanks a lot
发表于 2020-7-2 21:51:49 | 显示全部楼层
谢谢分享
发表于 2020-8-2 19:44:11 | 显示全部楼层
谢谢分享
发表于 2022-7-11 10:13:55 | 显示全部楼层
uestc1986 发表于 2016-6-21 18:43
可以看看这篇文章
谢谢
发表于 2022-8-24 10:31:08 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-22 18:15 , Processed in 0.016992 second(s), 4 queries , Gzip On, Redis On.
