查看: 4776|回复: 4
[求助] ICC中check_library之后说logic library和physical library不一致
发表于 2015-1-12 12:51:23 | 显示全部楼层 |阅读模式
报告如下:
#BEGIN_XCHECK_PHYSICALCELLS
Number of cells missing in physical library: 0 (out of 1020)
#END_XCHECK_PHYSICALCELLS
#BEGIN_XCHECK_PINS
Number of cells with missing or mismatched pins in libraries: 0
#END_XCHECK_PINS
Logic vs. physical library check summary:
Number of cells missing in logic library: 312
Information: Logic library is INCONSISTENT with physical library (LIBCHK-220)
#END_XCHECK_LIBRARY
1
这个问题用解决吗
发表于 2015-1-12 13:01:59 | 显示全部楼层
ignore
 楼主| 发表于 2015-1-12 14:34:56 | 显示全部楼层
回复 2# icfbicfb
那这个check_library命令的作用是什么?
#BEGIN_XCHECK_PINS
#END_XCHECK_PINS
是不是主要看上面这两条正确就可以啦,如果这俩不正确,就说明有问题,而底下那个 inconsistency 无所谓
发表于 2020-7-28 20:28:56 | 显示全部楼层
楼主请问这个问题你最后是怎么解决的,我也遇到了相同的问题
发表于 2020-7-28 21:28:47 | 显示全部楼层
我最后报的0
GMT+8, 2025-11-5 04:38 , Processed in 0.018043 second(s), 6 queries , Gzip On, Redis On.
